Constructing Overflow Detection Circuit with Logic Works
  • Thread starter Thread starter mathrocks
    Lost
The discussion revolves around constructing an overflow detection circuit for 4-bit signed-2’s complement addition using the Logic Works program. Participants seek clarification on the requirements of the homework assignment, the implementation of the circuit, and the detection of overflow conditions.
  • Homework-related
  • Some participants express confusion about the task, specifically regarding how to detect overflow in the circuit and what the expected outputs are.
  • It is noted that overflow can occur when both inputs have the same sign and the output has a different sign.
  • One participant suggests that to detect overflow, the leftmost bit (sign bit) of both inputs should be compared.
  • Another participant questions the meaning of "sign" in this context, seeking clarification on the terminology used.
  • Some participants reference external resources, such as diagrams and manuals, to aid in understanding the components and their functions in the circuit.
  • There is a mention of the maximum absolute value allowed in the 4-bit signed-2’s complement system being 7, which could relate to the overflow conditions.
Participants generally agree on the concept of overflow but have differing interpretations on how to implement the detection in the circuit. The discussion remains unresolved as participants continue to seek clarification and share their understanding.
Some participants express uncertainty about the specific implementation details, such as the role of the carry input (C0) and the function of various logic gates in the circuit. There are also references to external resources that may provide additional context but are not fully explored in the discussion.
This discussion may be useful for students working on similar homework assignments related to digital circuits, particularly those involving overflow detection in binary addition using signed-2’s complement representation.
mathrocks
My teacher assigned this problem for homework and I'm completely lost in what exactly I'm supposed to do. Btw "logic works" is a program we use to implement the circuits.
Using Logic Works, construct a circuit to detect overflow in 4-bit signed-2’s complement addition. Connect your circuit (in Logic Works) to the 4-bit adder included with your kit.
As discussed in class, overflow detection can be accomplished by comparing the sign of the addition inputs to the sign of the output. If the two inputs share the same sign and the output has a different sign, then overflow has occurred.
Hint: Can overflow occur if the two inputs have a different sign? No.
Use only parts available in your pencil box:
4-bit adder – 74_283
NANDs – 74_00
NOTs – 74_04
Further hint: Tie the carry input (C0) of the 4-bit adder to logic zero (or GND) lest you see a lot of unknown values in your output. Ignore the carry out bit (C4).
Test your circuit using a timing file for several different cases (at least 4), which clearly show examples of overflow and non-overflow. For each case explain what is happening in the circuit (i.e. “we are trying to add minus five to minus four and thus overflow because the circuit can only represent down to minus eight”).
I don't really understand what he wants me to do. Do I just build a circuit and the inputs are two 4 bit values and the adder adds the two binary numbers and somehow I detect to see if overflow occurred?
I don't understand what the output to the circuit would be? If overflow occurs what will happen? And how do I even detect overflow in my circuit in the first place.
I'm sorry if this is too detailed to answer, but I'm really confused about this whole thing.
Thanks a lot!
Thats what the task description says.
The sum of two numbers.
The sum will be wrong.
The task description actually tells you. Try reading it again.
I understand the concept of "overflow" but I don't understand how to actually implement it as a circuit. How do I make a circuit that understands how to compare the signs of the two inputs? That's where I'm getting stuck.
I'm going to attempt to make my question more clearer.
In order for overflow to occur the inputs must have the same signs or the last two carries are supposed to be the same. So in order to make this circuit I will need to compare the signs of the inputs since the adder I'm using ties all the internal carries together. Do I just look at the left most bit of the 4 digit value for both inputs and if they are equal then an overflow has occurred?
wow, when you say sign do you mean "not vs true"? part numbers seem a little short can you post diagrams?
i am intrigued, and trying to learn something. i have never heard of (or don't recall) anything about 4 bit signed 2's compliment addition for overflow detection with the co (?) input tied to gnd. (is co the trigger?).
please provide the answers when taken up in class.
thanks don
thanks don
http://www.ece.vt.edu/cel/ece2504/lab-manual-spring-2004.pdf
that's the link for the pdf with the part diagrams. The full adder chip is listed on page 9 while the other ones start on page 7. I believe C0 is the initial carry input.
And by sign I mean positive(0) value for negative(1) value. If both inputs are negative or both are positive then there will be a overflow I believe. I'm just confused on how to make the circuit reflect this.
Thanks!
http://engineering.dartmouth.edu/~engs031/hansen/outlines/21Arithmetic.pdf
Basically the circuit shown on page 8 is exactly what I need to compare the sign bits, but I'm having trouble understanding how they did this exactly. Like what do the AND and OR gates accomplish and if the output of the overflow is a 0 what does the zero mean?
Thank you
Do you understand that the maximum absolute number value allowed is 7?
  • · Replies 45 ·
