Register to reply
Modeling acceleration due to gravity for large bodies as a function of time
Share this thread:
NJJ289
#1
Jan24-11, 03:19 PM
P: 18
Given two bodies where GM/x^2=A and Gm/x^2=a, how might one model the acceleration of either bodies as a function of time?
A simpler version of the problem involves one of the masses being stationary (just for the sake of simplicity), so that GM/x^2=A and Gm/x^2=0.
A more complicated version would involve more than two bodies in multiple planes of space such that x1, x2, x3... etc. are vector quantities in 3 dimensions.
An even more complicated and accurate version would involve using integrated mass (taking into consideration the density distributions) instead of point mass.
I smell some serious calculus here but I can't wrap my head around how to do it. If anyone could explain how to do the simplest version or even what is involved that would be awesome. Also, any web resources on the kind of math involved or similar problems would be appreciated. Thanks!
Phys.Org News Partner Physics news on Phys.org
'Squid skin' metamaterials project yields vivid color display
Team finds elusive quantum transformations near absolute zero
Scientists control surface tension to manipulate liquid metals (w/ Video)
timthereaper
#2
Jan25-11, 12:03 PM
P: 343
You could use the differential form of Gauss' Law of Gravity:
[tex]\nabla \cdot g = -4 \pi G \rho[/tex]
You would have to specify the mass density at each point on the masses, but then you can obtain the gravitational vector field for each mass. That might help you get started.
Register to reply
Related Discussions
Why is Acceleration Due To Gravity Constant For All Bodies Irrespective Of Mass ? General Physics 39
Large bodies of mass and their effects on apparent time Special & General Relativity 2
Time for two bodies to collide under gravity. Introductory Physics Homework 19
Modeling Time to Cover Distance with variable acceleration General Physics 1
Simulating heat transfer as a function of time between two bodies Classical Physics 4
