Geometry problem. Circle and parallel lines to a circle.
The discussion focuses on solving a geometry problem involving a circle with a diameter of 90 located at (70, 100) and a point O at (0, 0). The objective is to find the coordinates of points A and B, where line OA extends from O to the circle at point A, and line BT is parallel to OA, tangent to the circle at a distance of 50 from OA. The solution involves setting up a quadratic equation based on the circle's equation and the line's slope, ensuring the discriminant equals zero for tangency, and solving a system of equations to determine the coordinates of points A and B.
  • Understanding of quadratic equations and their discriminants
  • Familiarity with the equation of a circle
  • Knowledge of slopes and tangent lines in geometry
  • Ability to solve systems of equations
  • Study the properties of quadratic equations and their discriminants
  • Learn how to derive the equation of a circle from its center and radius
  • Explore the concept of tangent lines and their geometric implications
  • Practice solving systems of equations involving linear and quadratic functions
Students and professionals in mathematics, particularly those studying geometry, as well as educators looking for practical examples of geometric problem-solving techniques.
naggy
A circle with diameter 90 is located at (70,100). A given point O is at (0,0). There is a line from O to the circle at point A, line OA. Line BT is parallel to OA at a distance 50 from OA and is a tangent to the circle.
How do I find the coordinates A and B?
I'm having problems drawing this so I can find A and B. Is there a way to do it?
Let (a, b) be the coordinates of point B. Any line through (a, b) is of the form y= m(x- a)+ b for some slope m. A circle with radius 90, with center at (70, 100) (I assume that is what you mean by saying the circle is "located at (70, 100)") has equation
[tex](x- 70)^2+ (y- 100)^2= 90^2[/itex]. <br /> Putting y= m(x- a)+ b into that gives<br /> [tex](x- 70)^2+(m(x-a)- 70+b)^2= 90[/itex]<br /> a quadratic equation for x where the line intersects the circle. A quadratic equaton can have: no real solutions (if the line does NOT intersect the circle), one solution (if the line is tangent to the circle), two solutions (if the line crosses through the circle). Here we want the line tangent to the circle which means there must be one solution and so the "discriminant" must be 0. That gives a condition relating a, b, and m. We can also find (x, y) at the intersection in terms of a, b, and m and find the equation of the line from the center of the circle, (70, 100) to (x,y). Of course, that line is perpendicular to the tangent line and so its slope must be -1/m. That gives another equation relating a, b, and m. Finally, the line from O to B is parallel to the radius and so also slope -1/m. That gives a third equation for a, b, and m. You should be able to solve those three equations for a, b, and m. (a, b) is, of course, B. The line OA will be y= mx with the same m you have just found. Solve the equations y= mx and [itex](x- 70)^2+ (y- 100)^2= 90^2[/itex] for the x and y of point A.[/tex][/tex]
  • · Replies 42 ·
