Register to reply
Final velocity given acceleration and initial velocity
by Ohoneo
Tags: acceleration, final, initial, velocity
Share this thread:
Ohoneo
#1
Jan25-11, 09:21 AM
P: 22
A dynamite blast at a quarry launches a chunk of rock straight upward, and 2.1 s later it is rising at a speed of 19 m/s. Assuming air resistance has no effect on the rock, calculate its speed at (a) at launch and (b) 5.2 s after the launch.
2. Relevant equations
v = v0 + at (I'm assuming is the only relevant one, although I'll post two others in case they are needed)
x = x0 + v0t + a/2 t^2
v^2 = v0*2 + 2a(x-x0)
3. The attempt at a solution
I solved part A by plugging into the equation v = v0 + at
19 m/s = v0 + (-9.8 m/s^2)(2.1 s)
And I found that the initial velocity equals 40 m/s.
So, to solve part b, I should just have to plug the initial in and find the final. I tried that:
v = 40 m/s + (-9.8 m/s^2)(5.2 s)
v = -11 m/s
However, when I entered that solution in for the homework, I was told it was wrong. I'm not really sure how to go about doing the problem if that's incorrect. I thought maybe I could have an error in rounding with significant figures.
Thanks for the help!
Phys.Org News Partner Science news on Phys.org
Security CTO to detail Android Fake ID flaw at Black Hat
Huge waves measured for first time in Arctic Ocean
Mysterious molecules in space
gneill
#2
Jan25-11, 09:53 AM
Mentor
P: 11,623
It could be that since part b asked for the speed, not the velocity, that the sign of the number reported should have been positive.
p21bass
#3
Jan25-11, 09:57 AM
P: 137
The problem asked for the speed of the rock - you gave its velocity. Remember - speed is a scalar (independent of direction), and velocity is a vector (depends upon direction).
edit: gneill and I were posting at the same time, apparently.
Ohoneo
#4
Jan25-11, 10:13 AM
P: 22
Quote Quote by p21bass View Post
I tried that as the answer (11 m/s instead of -11 m/s) and it was still incorrect.
p21bass
#5
Jan25-11, 10:19 AM
P: 137
No, that is the correct answer. 11.38 m/s to be "precise," but you're only given two significant figures in your initial conditions. I've done it three ways, and it comes to 11.38 m/s each time. And 40 m/s is correct for a. Just now, I did it a 4th way, and I got 10.96 m/s - which still rounds to 11 m/s.
Ohoneo
#6
Jan25-11, 10:40 AM
P: 22
Okay, so I did do the math correctly. Thanks for your help :) I'm going to email my professor and see what the issue is with that problem.
Register to reply
Related Discussions
How do you find final velocity with initial velocity and energy gained? Introductory Physics Homework 1
Rotating wheel initial angular velocity given final and time Introductory Physics Homework 2
Find Acceleration with only Initial Velocity and Final position? Introductory Physics Homework 6
Ratios of Initial to Final Energy/Momentum/Velocity Introductory Physics Homework 1
