Solving the Problem of Descending Balloons
  • Thread starter Thread starter discoverer02
The problem involves a balloon descending with constant acceleration and seeks to determine the weight of ballast that needs to be released for the balloon to ascend with the same acceleration. The discussion revolves around the forces acting on the balloon, including its weight and buoyant force, while neglecting air resistance.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of Newton's second law to analyze the forces acting on the balloon during descent and ascent. There are attempts to express the relationship between the weights and forces involved, with some participants questioning the correctness of their equations and assumptions regarding the buoyant force.
The discussion is ongoing, with participants exploring different interpretations of the forces involved. Some have offered insights into the relationships between the weights and forces, while others express confusion about the variables used. There is no explicit consensus, but several lines of reasoning are being examined.
Participants note the complexity of the variables involved, particularly the weights and masses, and some express uncertainty about the correct application of Newton's second law in this context. The problem is framed within the constraints of a homework assignment, which may limit the information available for discussion.
discoverer02
Here's the problem:
A balloon is descending with constant acceleration, a, (which of course is less than g). The weight of the balloon, with its basket and contents, is w1. In order to cause the balloon to accelerate upward with the same accelerations, a, what weight (call it w2 in your solution) of ballast needs to be released? Neglect air resistance. (You need to put in an unknown buoyant force on the balloon.)
The way I figure it there are two forces acting on the balloon there's the F up, and w1 or (w1 - w2) acting downward. When I use Newton's second law with just these two forces I get w2 = 2ma. The answer that I'm supposed to get is w2 = 2w1a/(g+a).
F - w1 = -ma, F - (w1 - w2) = ma
F = w1 - ma ===> w1 - ma -w1 + w2 = ma ==> w2 = 2ma.
I'm missing something. Any suggestions would be greatly appreciated.
Thanks
balloon going down with acceleration a:
F1 = -w1*(a+g)
you want to go up with acceleration a so you need 2 times force F1 in opposite direction:
F2 = 2F1=2w1(a+g)
got stuck here :(
the fault in your solution is this i think: F - w1 = -ma, that isn't right. and using w1 and m is also confusing i think
Actually the buoyant force remains unchanged. The downward force changes from w1 to w1 - w2, so the mass, in the case of the ascending balloon, changes to (m1 - m2)/g.
f - w1 = m(-a)
f - (w1-w2) = (m1-m2)a/g
the 'a' is the same, but in the opposite direction, and everything looks right, but it doesn't turn into the equations it's supposed to for w2.
very confusing all those w's and m's
but i think F-w1 != m(-a)
OK w1 = m1g.
Newton's Second Law: F = ma
The only forces on the balloon in the case where it's descending are the buoyant force F and the weight of the balloon so:
F - m1g = m1(-a) or F - w1 = m1(-a)
I finally figured this out. Shame on me. It took way too long!
Using Newton's Second Law.
Balloon descending: F - m1g = m1(-a)
Balloon rising: F - (m1 - m2)g = (m1 - m2)a
m1g - m1a = (m1 - m2)a + (ma - M2)g
m1g - m1g = m1a - m2a + m1g - m2g
-2m1a = -m2(g + a) Multiply both sides by g
2m1ga = m2g(g + a)
2w1a/(g + a) = w2
11K
