"Proof of a Formula for Differentiating x^p with Respect to y
The formula for differentiating y = x^p with respect to y is confirmed as dx^n/d^ny = p!/(p-n)! * x^{p-n}, provided that (-n)! = ∞ for natural numbers n. This definition allows the factorial function to extend to negative integers, ensuring the formula's validity. The nth derivative is derived using the limit of the difference quotient, leading to the conclusion that the formula holds true under the specified conditions.
  • Understanding of derivatives and the difference quotient
  • Familiarity with factorial functions and their extensions
  • Knowledge of natural numbers and their properties
  • Basic algebraic manipulation of polynomial expressions
  • Study the concept of factorials and their extensions to negative integers
  • Learn about the limit definition of derivatives in calculus
  • Explore advanced differentiation techniques for polynomial functions
  • Investigate applications of derivatives in solving real-world problems
Students and professionals in mathematics, particularly those focusing on calculus and differential equations, as well as educators teaching advanced differentiation techniques.
hedlund
Let y = x^p where p is a natural number. Is it true that
[tex]\frac{dx^n}{d^ny} = \frac{p!}{(p-n)!} \cdot x^{p-n}[/tex] with the restriction that we define [tex](-n)! \equiv \infty[/tex] for n=1,2,3... I found this formula and I believe that it is true if we define [tex](-n)![/tex] to equal [tex]\infty[/tex].
Your answer is correct, although you wrote the derivative upside down. The definition you used for (-n)! is the standard one.
The formula provided is indeed correct, as long as we define (-n)! to equal infinity for all natural numbers n. This definition allows us to extend the factorial function to negative numbers, which is necessary for the formula to hold true.
To prove this formula, we can use the definition of the derivative as the limit of the difference quotient. Let's start by taking the derivative of y = x^p with respect to x:
\frac{dy}{dx} = p \cdot x^{p-1}
Next, we can rewrite this as:
\frac{dy}{dx} = \frac{p}{1} \cdot x^{p-1}
From this, we can see that the coefficient of x^{p-1} is p, which is the same as the coefficient in the formula provided. Now, let's take the nth derivative of y with respect to x:
\frac{d^n y}{dx^n} = \frac{p}{1} \cdot \frac{p-1}{2} \cdot \frac{p-2}{3} \cdot ... \cdot \frac{p-(n-1)}{n} \cdot x^{p-n}
We can rewrite this as:
\frac{d^n y}{dx^n} = \frac{p!}{(p-n)!} \cdot x^{p-n}
This matches the formula provided, but with one key difference - the restriction that (-n)! equals infinity for all natural numbers n. This is necessary because as n increases, the denominator in the expression for the nth derivative becomes larger and larger, approaching infinity. Therefore, we must define (-n)! to equal infinity in order for the formula to hold true for all values of n.
In conclusion, the formula \frac{dx^n}{d^ny} = \frac{p!}{(p-n)!} \cdot x^{p-n} is correct for y = x^p, as long as we define (-n)! to equal infinity for all natural numbers n. This formula can be useful in solving problems involving derivatives of functions with a variable exponent, such as x^p.
  • · Replies 16 ·
