Velocity distribution functions, find rms velocity
The discussion revolves around the calculation of the root mean square (rms) velocity using the velocity distribution function from modern physics. Participants are exploring the integration of a given probability function related to molecular speeds and the implications of temperature on molecular velocities.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the integration of the velocity distribution function to derive the rms velocity. There are questions about the interpretation of the problem, particularly regarding the relationship between temperature and molecular speeds. One participant raises concerns about the clarity of the homework question and the validity of their calculations.
The discussion is ongoing, with participants sharing their attempts to understand the integration process and the implications of temperature on molecular speeds. Some guidance has been offered regarding a change of variable in the integral, but there is no explicit consensus on the correct approach or interpretation of the problem.
Participants note potential ambiguities in the homework question regarding the definition of speed in relation to temperature and the nature of molecular motion. There are also references to specific constants and relationships that may influence the calculations.
fahmed93
My friends and I have been working on this for the last two hours and we're still on 1a. I'm desperate and I'm going anywhere for help. If anyone's taken/is good at modern physics then please help. We're still in a physics review thing so it's not as complicated. The question is "Using the velocity distribution function, find the formula for the rms velocity."
The starting equation is P(v) = (m/2piKT)^3/2 * 4piV^2 * e ^ (-mv^2/2kT)
where m is mass, k is the Boltzmann constant, v is velocity, and t is temperature.
The answer is SQRT(3RT/M)
where R is the universal gas constant, T is temperature and M is molar mass.
Some useful conversions.
K = R/Na
where Na is Avagodro's number
m*Na = M
m = mass, Na = Avagodro's, M = molar mass
and we figured out that you're supposed to integrate it in this equation.
SQRT(integral from 0 to infinity of (v^2 * P(v) dv))
but don't understand how to go from there to the final answer.
PLEASE HELP!
Welcome to Physics Forums.
K = R/Na
m*Na = M
PLEASE HELP!
That integral is, essentially
[some constants]·∫vn e-mv2/2kT dv, where n=___?
integrated from 0 to ∞.
I suggest a change-of-variable, so that the exponential factor becomes simply e-x. You should get an integral that can be looked up, or evaluated numerically.
I would like to add a question here because I am too embarassed to go to my teacher for help. I have a homework problem and I must be doing something wrong on a really basic level because I think I am getting really bad answers.
"Calculate the temperatures for which the molecules x,y,z equal the speed of sound in air 340 m/s"
OK. The question is a little vauge I think because a) molecules never equal speed they travel "WITH" speed and b) at any temperature could a certain molecule reach a certain speed. It is a randomized distribution i.e. Boltzmann. OK so smart ones out there, does my H.W. ask for most probable speed or rms speed. And how would i find both? This is how I tried and came up with the wrong answers.
Used maxwell Boltzmann distribution. Df/dx = 0 when Vp = SQRT(2RT/M) (so says wikipedia: please correct me if I am wrong my book is of no help). So I squared the Vp which i want to be 340 m/s divided through by 2R multiplied by M and calculated. But my answers were in the neighborhood of 3-40 degrees kelvin for hydrogen and helium and water (unless somehow i got units different than kelvin, this answer is rediculus...i think). Wikipedia says Vrms = SQRT(3/2) * Vp which is also low. Am I doing something wrong? Is the correct temperature really so low? 40 degrees kelvin or less. I feel stupid.
So I forgot to tell you, Vp is the most proable velocity.
  • · Replies 21 ·
