Finding the resultant vector
by ryant14
Tags: vector, vector addition
ryant14
ryant14 is offline
#1
Jan27-11, 09:22 PM
P: 5
In the figure below shows the path taken by a drunk skunk over a level ground, from initial point i to final point f. The angles are θ1 = 30, θ2 = 50, and θ3= 80, and the distance are d1 = 5.00 m, d2 = 8.00 m, and d3 = 12.0 m. What are the (a) magnitude and (b) angle of the skunk’s displacement from i to f?
2. Relevant equations
Using basic trigonometric functions, soh cah toa
Let X and Y stands for the summation of x and y.
Resultant vector = (X2 + Y2)1/2
Let * stands for the resultant vector angle, then * = tan-1 = Y / X
3. The attempt at a solution
I have obtained the x and y component for d1. Finding x = (5.00 m)cos30 = 4.33 m and for y, (5.00m)(sin30) = 2.5 m. However, I'm having the difficulty to find the other x and y components of d2 and d3 because they aren't parallel to x and y axis respectively.
For example, d2 is diagonal and I can't simply do (8.00 m)(cos 50) to find the x component because d2 is not parallel to x axis. Hence, connecting d1 and d2 will not form a right triangle which is necessary to find the x and y components using soh cah toa..
Please give me an idea how to solve this..
Thank you..
PS. If the image link above doesn't work, pls. see the copy of this question in the attached file herein..
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
Register to reply
Related Discussions
Finding the resultant displacement vector. Introductory Physics Homework 1
finding the resultant and eq. for 3 vector on one point Introductory Physics Homework 3
Finding resultant force/vector help? Introductory Physics Homework 1
Finding the direction of the resultant vector of three vectors? Introductory Physics Homework 10
resultant vector Introductory Physics Homework 2
