Can Ax=0 Be Inconsistent? Solving Linear Equations with a Zero Constant
  • Context: Undergrad
  • Thread starter Thread starter Tryingtolearn
In the discussion, it is established that the equation Ax=0 is always consistent when b=0 in the system Ax=b, resulting in a unique solution where x=0. The only scenario where inconsistency arises is when b≠0, which can lead to no solution if the equations cannot be satisfied simultaneously. It is clarified that Ax=0 cannot be inconsistent when b=0, as this represents a special case with a guaranteed solution. The presence of additional variables can complicate the system but does not change the fundamental consistency of Ax=0 when b=0.
  • Understanding of linear algebra concepts, specifically linear equations.
  • Familiarity with matrix notation and operations.
  • Knowledge of the implications of consistent vs. inconsistent systems.
  • Basic understanding of unique solutions in linear systems.
  • Study the implications of the Rank-Nullity Theorem in linear algebra.
  • Learn about the conditions for consistency in systems of linear equations.
  • Explore the concept of homogeneous vs. non-homogeneous systems.
  • Investigate the role of additional variables in determining the consistency of linear equations.
Students of linear algebra, mathematicians, and educators looking to deepen their understanding of the consistency of linear systems and the implications of zero constants in equations.
Tryingtolearn
Hopefully someone can help me out with this one. I was in a conversation and the topic came up on what can an can not be inconsistent.
Assume that A, x, and 0 are all of the corrent order for Ax=0. According to everything I have learned, Ax=b if b=0 then it is always consistent. Does anyone know when your are solving a system of linear equations if there is every a case when b=0 and sill be inconsistent?
Your help is much appreciated.
If x=0, what is then Ax?
In order for Ax=0 to be inconsistent, there must be no solution or an infinite number of solutions for the system of equations. This means that there is no unique solution that satisfies all the equations in the system. In other words, there is no value of x that can make all the equations true simultaneously.
If b=0 in the system Ax=b, then there is always a solution. This is because when b=0, the system becomes Ax=0 which is a special case where there is always a unique solution, which is x=0. This is because any number multiplied by 0 is always equal to 0. Therefore, Ax=0 can never be inconsistent when b=0.
However, if b≠0, then it is possible for the system to be inconsistent. This is because when b≠0, the system becomes Ax=b and there may not be a value of x that can satisfy all the equations. In this case, the system is inconsistent and has no solution.
In summary, Ax=0 can only be inconsistent when b≠0 in the system Ax=b. When b=0, there is always a unique solution and the system is consistent. So, to answer the question, yes, there are cases when b=0 and the system is still inconsistent, but this only happens if there are other variables in the system besides x.
