How Does a Child's Spring Toy Car Transform Backward Motion into Forward Speed?
  • Context: Undergrad
  • Thread starter Thread starter dislect
    Car Mechanics Spring
The discussion revolves around the mechanics of a child's spring toy car, particularly how the backward motion of the spring mechanism translates into forward movement. Participants also explore methods to control the release of energy from a spring over a specified duration, focusing on mechanical solutions rather than electrical ones.
  • One participant seeks detailed mechanics of how a spring toy car operates, specifically how backward motion is converted to forward speed.
  • Another participant describes a typical mechanism involving a spring that is compressed and then released, questioning the specifics of the original poster's project.
  • A participant mentions the need for a metal rod to vibrate in a linear motion, expressing a preference for mechanical solutions over electric motors for reliability.
  • Concerns are raised about how the spring constant might affect oscillation rates and the limitations of length and rigidity in the design.
  • One participant suggests studying spring-driven clocks, noting their use of spiral springs and gears, while questioning their linear oscillation capabilities.
  • Another participant points out that clocks typically do not oscillate in a linear path and discusses the circular motion involved in their mechanisms.
  • A suggestion is made to use Da Vinci's slider device to convert circular motion into linear motion, proposing this as a potential solution for the project.
Participants express various viewpoints on the mechanics of spring systems and the feasibility of different designs. There is no consensus on the best approach to achieve the desired linear motion or the effectiveness of using spring-driven clocks as a model.
Participants acknowledge limitations regarding the length and radius of the components, as well as the challenges in achieving a controlled energy release over time. The discussion includes unresolved questions about the mechanics involved and the specific requirements of the project.
Individuals interested in mechanical engineering, toy design, or those exploring the principles of energy storage and release in mechanical systems may find this discussion relevant.
dislect
Hi all!
I tried searching the answer over the internet but with no luck - how does a child spring toy car works? the ones that you draw backwards and then release. I know that it works with a spring but I am interested in more exact details like how to spring draw back turns to circular motion.
Also while I am at it, what would be a good way to release energy stored in a spring through a determined amount of time? meaning, i can draw back the spring and release just like that but all the energy will be released right away in a short period of time. How can i extend that period of time using only mechanical components?
thanks !
p.s
This is NOT a homework question. Its for a little project of my own that I am thinking of doing.
Im not sure what kind of toy you are talking about, so the response will be slightly vague, but typically, if it is something like a dart gun, or something of the sort, it is essentially just controlled by a simple mechanism (typically just the thing you pull it back with) that compresses the spring, and locks it into place, then when you pull the release mechanism, the spring is decompressed.
As far as your project goes, what is it that youre trying to build? The amount of time you want to spread out the energy can affect your method. Do you want to operate it manually or does it need to be automated? I am a mechanical engineering student, so solving these little problems has become somewhat of a hobby.
im also a mechanical engineering student :) too bad that now days these kind of problem are mostly taking place as a hobby because my university consider these kind of stuff as low-tek ..
i need to make a metal rod vibrate up and down in a linear motion (no circular movement, atlist not one that is noticeable) and instead of using an elecric motor and creating somewhat of a offset and convert it to a linear motion i rather stay with mechanics for reliability reasons and use some sort of a spring to store energy (that you manually put into) and then release it. I need the metal rod to vibrate for about 5 seconds each time in about the same amplitude
any ideas how you can control the spread of energy release for a certain amount of time?
im trying to think if maybe the spring constant would have an effect on the ability to oscillate at a particular rate. is there a limit to the length you want to use? because common sense dictates, the longer the spring, the longer the wave to take to travel along it. I think the rigidity would also effect the speed of the wave. it is a perplexing problem haha.
well the length has its limitation, the max length is about 5cm and a radius of maybe 0.5cm tops. anyway, the smaller the better.
I figrued maybe i should try and study how spring-drawn clocks work like the old ones, it has some sort of a spiral spring (no constant radius) and it is combined with gears
the thing about clocks is that I don't think they oscillate in a linear path, I've pulled apart some mechanically driven alarm clocks and such to have a look, and the best I've come up with it that their compression is applied about a circular path or something like that
you can convert circulat to linear motion using the Da Vinci's slider device for example, there are some other options too. If you can create a circular motion with a high and somewhat constant angular speed using the principals of the clock mechanism its a good solution for me :)
Makes sense. I am not great at reading and imagining it haha, I am very tactile when it comes to this kind of stuff.
