New Reply
Gauss' Law: Solid Non-conducting Cylinder
Share Thread Thread Tools
Jan31-11, 12:30 PM   #1
A long, solid, non-conducting cylinder of radius 8 cm has a non-uniform volume density, ρ, that is a function of the radial distance r from the axis of the cylinder. ρ = A*r2 where A is a constant of value 2.9 μC/m5.
What is the magnitude of the electric field 7 cm from the axis of the cylinder?
2. Relevant equations
Volume of a cylinder: pi*L*R^2
Gauss' Law: ∫ E·dA = E(pi*L*R^2) = Qinside0
3. The attempt at a solution
ρ = A*r2 = (2.9x10^-6)*0.7^3 = 1.421e-8
ρV = (1.421x10^-8)* pi*0.7^2 = 2.18745955e-10
E = (Qinside*pi*r^2)/ε0 = 5.433109096 N/C
That does not look right at all to me, and I am not sure where my set up went wrong. Its obvious to me that I did not need the length of the cylinder so I ommited L (actually assumed a value of 1). Did I get the volume correct?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jan31-11, 01:05 PM   #2
Hi, Bryon.
First of all, we have Gauss' law:
[tex]\oint_\mathcal{S} \mathbf{E} \cdot d\mathbf{S} = \frac{Q_\text{int}}{\epsilon_0}[/tex]
The point where they ask you to get the E field is inside the cylinder, so to get this E field, you would need to set up a gaussian cylinder of radius 7 cm (I'd work symbolically until the very end) and use Gauss' law. The evaluation of the LHS is very easy, it is merely the E times the curved outer surface area of the gaussian cylinder (the sides don't add to the flux integral because there, E is perpendicular to the surface). Assuming that the cylinder is of radius [tex]r[/tex] and length [tex]L[/tex], this turns out to be [tex]E 2 \pi r L[/tex].
The RHS is slightly trickier, as this involves the total charge contained in the gaussian cylinder. That is:
[tex]Q_\text{int} = \int_V \rho dv[/tex]
To work out the differential element of volume, we remember that the volume of a cylinder is [tex]v = \pi r^2 L[/tex], and differentiating with respect to [tex]r[/tex], we have [tex]dv = 2 \pi r L dr[/tex]. We also have the charge density [tex]\rho[/tex] as a function of [tex]r[/tex]. Plugging it into the charge equation,
[tex]Q_\text{int} = \int_V \rho dv = \int_0^r A r'^2 2 \pi r' L dr' = \frac{A \pi L r^4}{2}[/tex]
where I added [tex]'[/tex] to the integrand to not confuse it with the upper limit. All you need to do now is set both sides of Gauss' law equal to each other, solve for the E field, and not forgetting to do unit conversion, evaluate it at r = 7 cm.
Notice how when you set them equal, the [tex]L[/tex]'s cancel out, as expected - this is a better method than to assume it's value to be 1. 1 What? cm? m?
Good luck.
Jan31-11, 01:41 PM   #3
Ah I see. I was not sure how to get rid of L. Which I just assumed to be 1m.
Jan31-11, 06:50 PM   #4
Ah now that I read your post I makes a lot more sense! Thanks!
New Reply
Thread Tools
Similar Threads for: Gauss' Law: Solid Non-conducting Cylinder
Thread Forum Replies
Help with gauss, Sheet vs conducting surface General Physics 18
Electric Field due to a charged hallow cylinder/solid cylinder on a point Introductory Physics Homework 7
Gauss' Law With conducting shells Introductory Physics Homework 0
Lovely physics XD - A conducting rod inside a conducting shell - electricity/gauss Introductory Physics Homework 17
Solid Conducting sphere inside a conducting spherical shell Advanced Physics Homework 2
