Effect of light and sound to opaque object
  • Thread starter Thread starter songoku
    Light Sound
The discussion revolves around the interaction of light and sound with an opaque object, specifically focusing on why an opaque object casts a shadow for light but not for sound. The subject area includes wave properties and behaviors, particularly in the context of sound and light waves.
  • Participants discuss the differences in wavelengths between sound and light, referencing the Huygens–Fresnel principle and diffraction. There are attempts to connect these concepts to the behavior of sound waves around the edges of the opaque object.
The discussion is ongoing, with participants exploring various aspects of wave behavior and seeking to clarify their understanding of the principles involved. Some guidance has been offered regarding the relevance of wavelength and diffraction, but there is no explicit consensus on the correct answer to the original question.
Participants express uncertainty about how to apply their knowledge of wave properties to the specific question posed. There is a noted lack of clarity regarding the relationship between the provided answer choices and the physical principles at play.
songoku
An opaque object 10 cm wide casts a shadow when placed in a beam of light but has little effect on a beam of sound emitted by a small source of frequency 500 Hz. This is because
a. sound is a pressure wave whereas light is an electromagnetic waves
b. sound travels much more slowly than light
c. sound waves are longitudinal whereas light waves are transverse
d. sound waves have a much longer wavelength than light waves
e. the power per unit area in a beam of sound is much lower than that in a beam of light
Don't know
I don't know the relation between the choices and the question. I know that sound is longitudinal and light is transverse, I know the speed of sound and light. But I don't know how to use the info to answer the question.
Thanks
Think of the difference of wavelengths and Huygens–Fresnel principle and diffraction of waves.
ehild
with a huge wavelength in the case of sound wave as compared to light waves,the pressure waves can really move over the edges of the object.
ehild
I read a little about Huygens-Fresnel principle at wiki.
"The Huygens–Fresnel principle is a method of analysis applied to problems of wave propagation (both in the far field limit and in near field diffraction). It recognizes that each point of an advancing wave front is in fact the center of a fresh disturbance and the source of a new train of waves"
But I still don't know how to relate it with the question. Huygens-Fresnel principle says that there will be a new center of disturbance. So when the sound hits the opaque object, there will be a new center of disturbance at the object's surface. Why don't the sound being reflected?
OK, based on your hint, I think the answer is (d). But why with a huge wavelength in the case of sound wave as compared to light waves,the pressure waves can really move over the edges of the object?
Thanks
  • · Replies 35 ·
11K
  • · Replies 19 ·
  • · Replies 22 ·
