How Do You Calculate the Mass at the Impaction Point of a Swinging Hammer?
  • Context: Undergrad
  • Thread starter Thread starter iliepins
    Energy
The discussion focuses on calculating the mass at the impaction point of a swinging hammer, specifically when swung pneumatically at the edge of the handle. The kinetic energy is calculated using the formula E=1/2mv^2, with a velocity of 5 m/s. The moment of inertia (I) is derived from the hammer's components, with the hammer head mass (M1) and handle mass (M2) contributing to the total moment of inertia. The kinetic energy upon impact is expressed as E = 1/2 * I * w^2, where w is the angular velocity.
  • Understanding of kinetic energy formulas, specifically E=1/2mv^2 and E=1/2 * I * w^2
  • Knowledge of moment of inertia calculations for different shapes
  • Familiarity with angular velocity and its relation to rotational motion
  • Basic principles of linear momentum and angular momentum
  • Learn about calculating the moment of inertia for complex shapes and systems
  • Explore the relationship between linear and angular momentum in mechanical systems
  • Study pneumatic systems and their applications in mechanical engineering
  • Investigate energy transfer during impact in collision mechanics
Mechanical engineers, physics students, and anyone involved in the design and analysis of swinging mechanisms or impact forces in engineering applications.
iliepins
Looking for quidance on calculating the mass at an impaction point of a swinging hammer. The hammer is set up to be swung pneumatically just at the edge of the handle in the horizontal plane. I understand the calculation E=1/2mv^2. Velocity is being measure just before the impaction point. So I'm happy with that and know the value. Let say v=5m/s. The question is on mass. the hammer head has a mass M1 and the handle has a mass M2. What is the mass to be used at the impaction point. M2, M2+M1, center of mass (but then how do i figure that), some other method? I want to simply calculate the energy being imparted at that point.
Since it is a rotational motion, I'd instead find the moment of inertia I of the hammer about the axis of rotation at the end of the handle, and then use the formula for the kinetic energy of the rotational motion at angular velocity w:
E = 1/2 * I * w^2
As an approximation, consider the hammer as consisting of two parts. Approximate the metal head with mass M1 at radius r=R1, and e.g. a rod of some mass M2 going from r=0 to r=R1 (assuming homogeneous mass distribution along its length).
The moment of inertial about r=0 of the head in this approximation is I_h = M1*R1^2 since we are approximating it as a point.
The moment of inertial about r=0 of a radial rod of mass M2 of length R1 is (from looking it up on wikipedia) I_r = 1/3 * M2 * R1^2 (please double-check this...)
Thus, the moment of inertial about r=0 of the entire hammer in this approx is I = I_h + I_r.
Then the kinetic energy if the hammer is E = 1/2 * I * w^2 where w is the angular velocity (in radians per second) of the rotational motion upon impact.
It is of course possible to find a more accurate moment of inertia of the hammer by not assuming the head to be located at one point.
Of course, if the head is much more massive than the handle, then your can just approximate everything by incoming linear motion of the head at v=5m/s.
welcome to pf!
hi iliepins! welcome to pf! :smile:
why do you want the energy?
the effect is measured by the momentum of the hammer, p = mv (or by the angular momentum, Iω, if the hammer is too extensive) :wink:
27K
