What are the implications of work and pressure changes in thermodynamics?
  • Thread starter Thread starter dhoyda
    Thermodynamics
This discussion focuses on the implications of work and pressure changes in thermodynamics, specifically comparing two scenarios involving gas in a cylinder. In the first scenario, gas escapes to the atmosphere, while in the second, it expands to atmospheric pressure with the piston still in place. The key conclusion is that additional work is required to compress gas that has escaped into the atmosphere compared to gas that remains contained. The discussion highlights the significant difference in work needed when dealing with gases like carbon dioxide versus air due to their respective pressures.
  • Understanding of basic thermodynamic principles
  • Familiarity with gas laws and pressure concepts
  • Knowledge of work-energy principles in physics
  • Experience with pressure measurements (e.g., Pascal, atm)
  • Research the First Law of Thermodynamics and its applications
  • Explore the Ideal Gas Law and its implications for work done
  • Study the behavior of real gases versus ideal gases
  • Investigate the concept of pressure-volume work in thermodynamic systems
This discussion is beneficial for students of physics, engineers working with thermodynamic systems, and anyone interested in the practical applications of gas behavior under varying pressure conditions.
dhoyda
Lets say we have a gas under pressure in a cylinder with my hand on the piston. I let my hand go and the piston shoots off the cylinder and the gas escapes to the atmosphere.
I take that same arrangement of gas in the cylinder under a piston and I arrange a scenario so that the gas expands to a pressure equal to that of the atmosphere. Note that the piston is still fitted on the cylinder just in a different location.
Now, I can push that gas down to the same pressure it was in the first scenario by the force of my hand on the piston head. I have done some work.
But if I want to take the gas that has escaped into the atmosphere and push it down to the same pressure with the piston that it was before I must do additional work by getting it out of the atmosphere not to mention the work that was done by pushing it down.
So the work that is the same in both cases is the work i expended to push the piston down on the gas.
What have I stumbled upon in my analysis?
I really wonder what you have stumbled upon in your analysis.
If your gas happens to be air there is little diffence between the 2 cases.
If your gas is carbondioxide (to show it might be a real problem) you can expand till the pressure is 1 atm=101325 Pa (case 2). The pressure of CO2 in the atmoshere is about 30 Pa, so a lot more expansion would be needed to get there (case 1).
Maybe you can reformulate your question now ?
  • · Replies 67 ·
  • · Replies 27 ·
