| New Reply |
Number Theory |
Share Thread | Thread Tools |
| Feb4-11, 06:25 PM | #1 |
Number Theory
Let n>=2 and k>0 be integers. Prove that (n-1)^2 divides n^k -1 if and only if (n-1) divides k.
| Feb4-11, 06:47 PM | #2 |
you may want to check [tex]\varphi{([n-1]^2)}[/tex]
| Feb4-11, 06:56 PM | #3 |
I know that (n-1)^2 | (n^k-1) means that (n-1)^2 *m= (n-1)(n^[k-1]+n^[k-2]+...+n+1). But how do I connect this with (n-1)*a=k? Thanks.
| Feb4-11, 06:58 PM | #4 |
Number Theory |
| Feb4-11, 10:35 PM | #5 |
I'll do the part <==, then you try to do the part ==> prove that if n-1|k, then [tex](n-1)^2|n^k-1[/tex]: proof: first what is [tex]\varphi{([n-1]^2)}[/tex] ?? it is [tex](n-1)^{2-1}\cdot \varphi{(n-1)}=(n-1)\cdot \varphi{(n-1)}[/tex] now, by euler, as [tex]gcd(n-1,\ n)=1[/tex] then [tex]n^{\varphi{([n-1]^2)}}=n^{(n-1)\cdot \varphi{(n-1)}}\equiv\ 1\ mod\ (n-1)^2[/tex] and by Lagrange we know that either [tex]k=(n-1)\cdot \varphi{(n-1)}[/tex] or [tex]wk=(n-1)\cdot \varphi{(n-1)}[/tex] notice that [tex]\varphi{(n-1)}<n-1<k[/tex], and by hipothesis n-1|k EDIT: conclusion is: therefore [tex]n^k\equiv\ 1\ mod\ (n-1)^2[/tex] |
| Feb4-11, 10:36 PM | #6 |
Thank you! But at this moment we didnt study anything about Phi function. Do you know any other method?
| Feb5-11, 10:59 AM | #7 |
(...)and by Lagrange we know that either [tex]k=(n-1)\cdot \varphi{(n-1)}[/tex] or [tex]k=(n-1)\cdot \varphi{(n-1)}w[/tex] popitar, try to rewrite and "play" with the equations you know related to it, factoring x^k-1 is a way, did your teacher give any similar problem with solutions? |
| Feb5-11, 11:13 AM | #8 |
Thank you so much, Al-Mahed!
Factoring x^k - 1 is (x-1)(x^[k-1]+x^[k-2]+...+x+1), and I see that (x-1)^2 divides x^k-1means that (x-1) divides (x^[k-1]+x^[k-2]+...+x+1), but I don't see how I connect this with (x-1) divides k.. |
| Feb5-11, 11:37 AM | #9 |
how many elements you have in x^[k-1]+x^[k-2]+...+x+1 ? |
| Feb5-11, 11:40 AM | #10 |
I believe k elements.
| Feb5-11, 11:53 AM | #11 |
correct, k elements, now you must show some work on it, grab a coffe (if you like) and think about it hint: what means "x-1 divide k" in terms of euclidian form a=qb+r? how could you WRITE it down as an equation? and how to use it? you already saw by yourself you need to prove that x-1 divide x^[k-1]+x^[k-2]+...+x+1 |
| Feb5-11, 12:14 PM | #12 |
(x-1) divides k means (x-1) * p = k for some p positive integer. Then I multiply it by (x-1) I get the following (x-1)^2*p=k*(x-1). Then I can say that x^k-1 = k*(x-1)? But (x-1)*z=x^[k-1]+x^[k-2]+...+x+1.. ahh
| Feb5-11, 12:22 PM | #13 |
This is all I have
(x-1)^2 | x^k - 1 <=> (x-1)|k (x-1)^2 * m = x^k -1 <=> (x-1)*z=k (x-1)^2 *m = (x-1)(x^[k-1]+x^[k-2]+...+x+1) <=> (x-1)*z=k (x-1)*m = x^[k-1]+x^[k-2]+...+x+1 <=> (x-1)*z=k |
| Feb5-11, 12:43 PM | #14 |
write x-1=a, then k=ma=m(x-1) for some integer m, since x-1| k, it yields x=a+1
x^[k-1]+x^[k-2]+...+x+1 = (a+1)^[k-1]+(a+1)^[k-2]+...+(a+1)+1 = a*S + k=(x-1)S+m(x-1), since you'll have k 1's, and the rest of it multiplied by a |
| Feb5-11, 12:55 PM | #15 |
Can you explain this part :(a+1)^[k-1]+(a+1)^[k-2]+...+(a+1)+1 = a*S + k?
| Feb5-11, 01:04 PM | #16 |
Ok. So you said I replace (x-1) by a, and x=a+1
(x-1)^2 | x^k - 1 <=> (x-1)|k (x-1)^2 * m = x^k -1 <=> (x-1)*z=k (x-1)^2 *m = (x-1)(x^[k-1]+x^[k-2]+...+x+1) <=> (x-1)*z=k (x-1)*m = x^[k-1]+x^[k-2]+...+x+1 <=> (x-1)*z=k a*m=(a+1)^[k-1]+(a+1)^[k-2] + ...+ (a+1)+1 <=> a*z=k And from here what to do? Thanks! |
| Feb5-11, 01:41 PM | #17 |
Prove that a divides bc if and only if a/(gcd(a,b)) divides b.
| New Reply |
| Tags |
| number theory |
| Thread Tools | |
Similar Threads for: Number Theory
| Number Theory: Calculating mod large number | Calculus & Beyond Homework | 9 | ||
| Number Theory | Calculus & Beyond Homework | 4 | ||
| measure theory and number theory? | Linear & Abstract Algebra | 18 | ||
| Division theory..and Prime Number theory.. | Linear & Abstract Algebra | 3 | ||
