Particle Motion: Units of Constants, Maximum Position and Speed
  • Thread starter Thread starter strugglin-physics
    Test
The motion of a particle along the x-axis is described by the function x(t) = ct² - bt³, where c and b are constants. The units of c are determined to be m/s², while the units of b are m/s³. To find the largest positive position of the particle, one must calculate the extrema by taking the first derivative of the function and setting it to zero, leading to a quadratic equation. The maximum speed of the particle can be determined by analyzing the velocity derived from the position function.
  • Understanding of calculus, specifically derivatives
  • Familiarity with units of measurement in physics
  • Knowledge of quadratic equations and their properties
  • Basic concepts of particle motion in physics
  • Study how to derive functions and find critical points using calculus
  • Learn about the physical interpretation of derivatives in motion
  • Explore the application of the quadratic formula in real-world scenarios
  • Investigate the relationship between position, velocity, and acceleration in particle motion
Students and professionals in physics, particularly those studying mechanics, as well as educators looking to explain particle motion concepts effectively.
strugglin-physics
The postiion of a particle able to move left or right along the x-axis is given by the function x(t) = ct^2 - bt^3, where c and b are constants. Your answers will be in terms of these two constants.
What are the units of c? What are the units of b?
What is the largest positive x position reached by this particle?
Does the particle reach a maximum speed (either positive or negative)? If so what is its maximum speed. If not, explain why not.
I know that the slope is the velocity, which is m/s but I don't know which one is the slope. As for the largest positive x position... I thought about maybe using the quadratic formula but the function is not really appropriately setup.
Any help would be appreciated.
since x is in m(etres) and t is in s(econds) a will have to be in : m/s²
b will have to be in m/s³
you know why ?
marlon
you have a function of which you need to know the maximum. Minima and maxima are called the extrema. These extrema can be calculated by taking the first derivative to t of the function x(t), and setting it equal to 0. You will get a quadratic formula and you need to solve this equation. This yields at best two different solutions. Just check out what solution corresponds to the maximum. There are several ways to do this. The most easy one is looking where the function is positive and negative...good luck
marlon
  • · Replies 40 ·
