Register to reply
Finding the angle when given the coefficient of friction
by NYILoveYou
Tags: angle, coefficient, friction
Share this thread:
NYILoveYou
#1
Feb11-11, 04:01 PM
P: 7
A mop is being used to clean a floor. The coefficient of friction between the mop and floor is 0.3. Find the angle between the handle and the horizontal when the mop head is moving at constant velocity.
2. Relevant equations
The coefficient of friction = Friction/ Normal Force
Pythagoras Theorem
3. The attempt at a solution
I figured, the main force would be gravity at 9.8 as mass is negligible. I also tried to get the components of the force. If the downward force was 9.8m/s, the horizontal would be 0.3*9.8 - 2.94 (?). The normal force would also be 9.8, as there is not vertical acceleration or velocity.
I thought could you say perhaps, 2.94/9.8 and the inverse sine of this? It does give the right answer but it feels like the working is incorrect..
Please help, any pointers would be appreciated.
Phys.Org News Partner Science news on Phys.org
Physical constant is constant even in strong gravitational fields
Montreal VR headset team turns to crowdfunding for Totem
Researchers study vital 'on/off switches' that control when bacteria turn deadly
Doc Al
#2
Feb11-11, 04:25 PM
Mentor
Doc Al's Avatar
P: 41,579
Quote Quote by NYILoveYou View Post
If the mass is negligible, then so is the force of gravity.
Do this: Assume that some force is being applied along the line of the mop handle. Call it F. Call the angle that the mop makes with the floor θ. Now figure out the horizontal and vertical forces on the mop.
ashishsinghal
#3
Feb12-11, 05:10 AM
P: 460
Hint: you are missing a major point. there is a force holding the mop. otherwise the mop will fall.
ashishsinghal
#4
Feb12-11, 05:11 AM
P: 460
no...the mass is not negligible. if that is so then gravity, normal and friction force would all be negligible. consider all forces and apply the concept of torque..
Doc Al
#5
Feb12-11, 06:07 AM
Mentor
Doc Al's Avatar
P: 41,579
Quote Quote by ashishsinghal View Post
That is incorrect.
NYILoveYou
#6
Feb12-11, 12:41 PM
P: 7
Quote Quote by Doc Al View Post
Well the horizontal force would be cos θ = 0.3/F
I'm not too sure on the vertical component as you don't actually have the opposite side?
Doc Al
#7
Feb12-11, 04:29 PM
Mentor
Doc Al's Avatar
P: 41,579
The horizontal component of the force F would be Fcosθ.
You may need to review how to find the components of a vector. See:
Trigonometric Method of Vector Resolution
Resolving a Vector Into Components
NYILoveYou
#8
Feb12-11, 05:07 PM
P: 7
Thanks, I remember now,
so the horizontal component is Fcosθ
the vertical component would be Fsinθ
i still don't see how that will help, as you don't actually have F or θ
Doc Al
#9
Feb12-11, 05:11 PM
Mentor
Doc Al's Avatar
P: 41,579
Good.
Those aren't the only forces acting on the mop. What about the normal force and friction?
NYILoveYou
#10
Feb14-11, 03:15 PM
P: 7
Good.
The normal force would be equal to friction, as the mop is moving at constant velocity,
Fr=coefficient of friction x the normal force?
Doc Al
#11
Feb14-11, 05:32 PM
Mentor
Doc Al's Avatar
P: 41,579
Not exactly. Since, the velocity is constant the net force is zero. That means that the horizontal component of the applied force (F) must equal the friction force.
Right!
NYILoveYou
#12
Feb15-11, 11:19 AM
P: 7
Right!
Thanks, so if
Fcosθ = Friction
And if friction = the coefficient of friction x the reaction force,
and the reaction force (R) = Fsinθ
would it be...
Fcosθ = 0.3 x Fsinθ?
Doc Al
#13
Feb15-11, 11:31 AM
Mentor
Doc Al's Avatar
P: 41,579
would it be...
Looks good. Now just solve for θ. (Rearrange a bit and reach for your calculator.)
NYILoveYou
#14
Feb19-11, 01:41 PM
P: 7
Well I tried that, but then I got stuck...
The F's cancel out.
Move the sinθ to the other side, so you get
Cosθ/Sinθ = 0.3
then I got stuck, I was thinking perhaps you could use trigonometric proofs?
Doc Al
#15
Feb19-11, 02:15 PM
Mentor
Doc Al's Avatar
P: 41,579
So far, so good. Can you replace that ratio of trig functions--or its inverse--with a single trig function? Then use your calculator.
NYILoveYou
#16
Feb19-11, 03:55 PM
P: 7
THANKS!! I finally did it! Thank you so much! :D
Register to reply
Related Discussions
Relationship between the coefficient of friction and the angle of friction: Proof Introductory Physics Homework 1
Calculating Force at an angle with kinetic friction coefficient Introductory Physics Homework 11
Finding coefficient of friction and angle of incline Introductory Physics Homework 3
Finding an angle given only the Coefficient of static friction Introductory Physics Homework 5
Friction coefficient and critical angle Introductory Physics Homework 3
