Proving the Sum of Cosines: A Homework Challenge
The discussion revolves around proving the sum of cosines, specifically the expression \(\sum_{k=0}^{4}\cos^2\left({\frac{2\pi k}{5}\right) = 5/2\). Participants are exploring trigonometric identities and algebraic techniques to validate this equation.
  • Participants are attempting to use trigonometric identities, such as the half-angle formula, to simplify the expression. There are questions about the cancellation of terms and the rationality of the results. Some participants suggest visualizing the problem with diagrams to understand the distribution of the cosine values.
The discussion is ongoing, with participants sharing various approaches and insights. Some have provided guidance on using trigonometric identities, while others are questioning the effectiveness of their methods. There is no explicit consensus yet, but several productive lines of reasoning are being explored.
Participants note that numerical evaluations yield results close to the expected value, but there is uncertainty about the algebraic proof. The discussion includes references to external resources for trigonometric values related to the angles involved.
Dragonfall
[tex]\sum_{k=0}^{4}\cos^2\left({\frac{2\pi k}{5}\right) = 5/2[/tex]
I have to prove that. I don't know how. Maple gives
[tex]1+2*cos((2/5)*Pi)^2+2*cos((1/5)*Pi)^2[/tex]
evaluated numerically it is equal to 2.499999. But I don't remember the trick to doing this algebraically.
Hi Dragonfall! :smile:
(have a pi: π and a sigma: ∑ and try using the X2 icon just above the Reply box :wink:)
Use one of the standard trigonometric identities for cos2 :wink:
Using the half angle formula I get the terms as
[tex]1+\cos\left(\frac{4k\pi}{5}\right)[/tex]
There does not seem to be a way to cancel them out or write them as nice, rational numbers.
Actually, half that! :wink:
ok, the "1" neatly gives the correct answer on its own, so all you need to do is to prove that the five cosines all add to zero …
have you tried drawing a diagram of them? :smile:
Unfortunately, if I draw a diagram, the Y values cancel out. The X values, which are cos, do not.
ok, maybe just looking at the diagram doesn't do it,
but you can see they're evenly spaced, so you're adding ∑ cos(nπ/5) …
that's the real part of ∑ en(2πi/5), = ∑ (e(2πi/5))n,
which is easy algebra. :wink:
I believe you mean:
[tex]1+2\cos^{2}((2/5)\pi)+2\cos^{2}((1/5)\pi)[/tex]
For the following see: Weisstein, Eric W. "Trigonometry Angles--Pi/5." From MathWorld--A Wolfram Web Resource. http://mathworld.wolfram.com/TrigonometryAnglesPi5.html
[tex]\cos\left(\frac{\pi}{5}\right)=\frac{1}{4}\left(\sqrt{5}+1\right)[/tex]
[tex]\cos\left(\frac{2\pi}{5}\right)=\frac{1}{4}\left(\sqrt{5}-1\right)[/tex]
