What Is the Equilibrium Constant for This Reaction?
The equilibrium constant (Kc) for the reaction CO2 + H2 <-> CO + H2O was calculated based on a mixture of 0.229 mol CO2, 0.229 mol H2, and 0.328 mol H2O in a 2.0 L container. The equilibrium concentration of H2O was determined to be 0.210 M, leading to an expected Kc value of approximately 2.06. The calculations involved determining the equilibrium concentrations of all species and applying the formula Kc = [CO][H2O]/([CO2][H2]). The final computed Kc value was confirmed to be 2.0587.
  • Understanding of chemical equilibrium concepts
  • Familiarity with the equilibrium constant expression (Kc)
  • Ability to perform stoichiometric calculations
  • Knowledge of concentration units (Molarity)
  • Review the concept of chemical equilibrium and Le Chatelier's principle
  • Learn about the calculation of equilibrium constants for different reactions
  • Practice stoichiometric calculations involving multiple reactants and products
  • Explore the impact of temperature and pressure on equilibrium constants
Chemistry students, educators, and professionals involved in chemical engineering or reaction kinetics who seek to deepen their understanding of equilibrium constants and their calculations.
Raul3140
Equilibrium constant question?
A mixture of 0.229 mol CO2, 0.229 mol of H2, and 0.328 mol of H2O are placed in a 2.0 L container. The following equilibrium is established:
CO2 + H2 <-> CO + H2O. The equilibrium concentration of H2O is 0.210 M. Calculate the equilibrium constant (Kc)
Kc=Products/reactants...raised to their stochiometric coefficients.
I keep getting 2.011 I used the stochiometric relationship to determine the changes in concentration.
The answer is supposed to be 2.06
I got 2.06 , or 2.0587 to be exact.
If you are that close you have probably not made any great mistake of principle.
Have you carried through the arithmetic to full precision at each stage?
Your equilibrium [CO2] and [H2] are equal? (0.0685 M)
One thing you may find profitable is instead of going through your work, you totally recalculate without looking at it. It goes a lot faster this time which boosts confidence. But perhaps you have already done that.
If there is a small arithmetical error only it will lose you very few marks if any in most sensible exams etc.
Checking whether your equilibrium [H2] + [H2O] adds up to the initial sum as it should, and similarly for the other pair might localise any error.
[CO] = 0.046 M
9K
