| New Reply |
Minimizing Sum of Absolute Values |
Share Thread | Thread Tools |
| Feb16-11, 03:37 AM | #18 |
| Feb16-11, 06:57 AM | #19 |
Mentor
| Feb16-11, 07:41 AM | #20 |
@Redbelly98 : Exactly what I want to say
| Feb16-11, 07:49 AM | #21 |
Mentor
No problem.
Here's a representative graph. (Ignore the zj-1, etc. This comes from a google image search and I took the best graph I could find): In general, the minimum could be at any one of the critical points. In some special cases, there could be a horizontal line for part of the function -- but even then evaluating the function only at the critical points will yield the minimum value. |
| Feb16-11, 08:09 AM | #22 |
Awesome, thanks everybody for your help! That answers the question!
| Feb22-11, 02:21 AM | #23 |
I recently encountered another problem, but it extends this topic. Instead of opening a new thread I guess this place is as good as any..
If one defines the function [tex]E=|1-x-y| + |4-2x-y| ...[/tex] how can I find it's minimum now (x and y coordinates)? Can this be extended to N variables inside each absolute value? Each absolute value will be linear... I am not sure if the above answer can be generalized to suit this problem? Any ideas? ![]() Cheers, Adrian |
| Feb22-11, 06:44 AM | #24 |
Mentor
If there are just two terms for E, then find x and y so that both terms are zero.
If there are more than two terms for E, I will have to think about it some more. |
| Feb22-11, 07:18 AM | #25 |
Mentor
Okay, I've got it.
You need to consider all possible pairs of expressions, and find (x,y) where both terms in the pair equal zero. Then evaluate E at all such points, and take the minimum. So if E has three terms, there are 3 ways to pair up the terms. If E has four terms, there are 6 ways to pair them up. Etc. If that's not clear, let me know. |
| Feb22-11, 08:31 AM | #26 |
Able to elaborate on the reasoning of this?Cheers! Adrian |
| Feb22-11, 09:42 AM | #27 |
Mentor
Okay.
First, consider just one absolute value expression, z=|ax + by + c|.The line defined by ax+by+c = 0 divides the xy plane into two regions. In one region, the absolute value argument is positive and z = ax+by+cOn the other side of the line ax+by+c=0, the absolute value argument is negative and z = -ax-by-c.So the graph of z is of two tilted half-planes that meet along the line ax+by+c=0. Hopefully you can visualize that. Next consider several absolute value expressions, z = |a1x + b1y + c1| + |a2x + b2y + c2| + ...Setting each absolute value argument aix + biy + ci=0, we get several intersecting lines in the xy plane, dividing the xy plane into distinct regions as shown in this figure: Within each region, the graph of z(x,y) is of a tilted plane. Each region is described by a different plane, and adjacent planes intersect along one of the lines. The entire graph resembles a polyhedral surface, and the minimum of the function must occur at one of the vertices of the "polyhedron", namely at an intersection of a pair of lines. So you have to find the intersection of each pair of lines, and evaluate z(x,y) at all such intersection points. |
| Feb23-11, 06:37 AM | #28 |
Awesome, thanks a lot Redbelly! Really appreciate that! :)
| Jul21-12, 11:33 PM | #29 |
Without plodding through a convex solver manual, one can efficiently find the minimum point using the below method:
The above algorithm has an overall runtime complexity of [itex]O(n\log{n})[/itex], due to the sorting procedure in step (3). It would be good if somebody can introduce an algorithm which runs in linear time .Otherwise, the above algorithm can be adapted for the case of [itex]f(\vec{x})= \sum_{i}|\vec{a_{i}}^{T}\vec{x}+b_i|[/itex], by holding all but one variable in [itex]\vec{x}[/itex] as constant. The algorithm has to be applied repeatedly to every variable in a round robin fashion. Convergence is guaranteed, but I cannot put a bound on the number of iterations required. A good initial value for [itex]\vec{x}[/itex] to start the iteration is [itex]-A^{\dagger}\vec{b}[/itex], where the rows of [itex]A[/itex] are [itex]\vec{a_{i}}^{T}[/itex], and the entries of [itex]\vec{b}[/itex] are [itex]b_i[/itex]. An algorithm which jointly optimizes for all variables in [itex]\vec{x}[/itex] is welcomed. |
| Jul22-12, 03:00 AM | #30 |
Would it be possible to find the minimum by squaring the function inside the absolute value signs then carrying out the necessary steps to find a minnima/maxima? I think this should work for any polynomial, not sure about other functions though.
| Jul22-12, 03:55 AM | #31 |
| Jul22-12, 08:15 AM | #32 |
minimize a + b + c + d subject to a - b = 1 - x - y c - d = 4 - 2x - y a, b, c, d >= 0 The trick is that if [itex]1 - x - y \ge 0[/itex], then [itex]a = 1 - x - y[/itex] and [itex]b = 0[/itex]; otherwise [itex]a = 0[/itex] and [itex]b = - (1 - x - y)[/itex]. So [itex]a + b = |1 - x - y|[/itex] in all cases. You might think that other solutions are possible-- for example, if [itex]1 - x - y = 2[/itex], then [itex]a = 3[/itex] and [itex]b = 1[/itex] seems to be an alternative solution that would mess things up. But this will never happen if you are using the Simplex Algorithm, because it is guaranteed to always find a solution at a vertex of the feasible polyhedron. At least one of [itex]a[/itex] and [itex]b[/itex] will always be zero. |
| Jul22-12, 02:04 PM | #33 |
| Aug6-12, 01:54 AM | #34 |
| New Reply |
| Thread Tools | |
Similar Threads for: Minimizing Sum of Absolute Values
| Absolute values | Precalculus Mathematics Homework | 5 | ||
| Absolute values | General Math | 4 | ||
| Absolute Values | Precalculus Mathematics Homework | 5 | ||
| Help On Absolute Values | Introductory Physics Homework | 3 | ||
| Absolute values | Introductory Physics Homework | 12 | ||
