Why does a circles angles equal up to 2pi? Wouldn't it be 1?
  • Context: High School
  • Thread starter Thread starter Cyberice
    Angles Circles
The discussion revolves around the concept of angles in a circle, specifically the relationship between degrees and radians, and why a full circle is defined as 2π radians rather than π. Participants explore the definitions and implications of these measurements in geometry and trigonometry.
  • Homework-related
  • One participant questions why a circle's angles equal 2π, suggesting it should be π based on their understanding of degrees.
  • Another participant clarifies that 2π radians correspond to 360 degrees, explaining the relationship between radians and degrees.
  • A participant explains that 1 radian is defined as the angle subtended by an arc equal in length to the radius, leading to the conclusion that there are 2π radians in a circle.
  • Some participants note that using radians simplifies calculations in calculus, particularly with trigonometric functions.
  • One participant mentions the historical context of Euler's use of radians in trigonometry.
  • A later post defines the term "subtended," clarifying its meaning in the context of angles and arcs in a circle.
Participants generally agree on the definition of radians and the relationship between radians and degrees, but there is some initial confusion expressed by the original poster regarding these concepts. The discussion remains exploratory without a definitive resolution of all misunderstandings.
Some participants express uncertainty about the definitions and relationships between radians and degrees, indicating a need for further clarification or resources.
Students studying geometry or trigonometry, educators looking for discussion examples, and individuals interested in the mathematical foundations of angle measurement.
Cyberice
Why does a circles angles equal up to 2pi? Wouldn't it be 1pi? Please help.
My geometry teacher (last year - and now he's gone) drew a circle for me and defined all the points in terms of pi (is there an ASCII character for pi, by-the-way, on the keyboard?). Where the 90 degree point would be he put 1/2 pi, were the 180 degree point was he put just 'pi', at 270 he put 3/2 pi, and 360 he put 2 pi. What the heck?! I thought pi was the ratio of the diameter to the circumference. If that is true then shouldn't it be: at 90 degrees 1/4 pi, at 180 deg. 1/2 pi, 270 deg. 3/4 pi, and 360 deg. just 'pi'? Can you explain this or direct me to a site that can? Please, I'm going crazy trying to figure it out.
Mathematics news on Phys.org
It's 2Pi radians. One radian is equal to 57.2958 degrees.
Therefore, 2pi radians would be 2 x 57.2958 x 3.1416 = 360 degrees
What your geometry teacher was doing was marking out the circles in Radians.
1 Radian is the angle that an arc the same length as the radius of the circle will make.
And since, as you pointed out, the ratio of diameter to circumference is [pi], and the radius is 1/2 the diameter, there are 2[pi] radians to a circle.
Thus a quarter of the way around the circle is 1/2 [pi] radians, half way [pi] radians, three quarters, 1 1/2 [pi] radians and all the way around 2[pi] radians.
Radians are the natural way to divide up a circle. ( the number of degrees were just an arbitary choice)
Thank you! I was wondering about that and it really bothered me. BTW, would you happen to know any sites that could explain it also (just for the heck of it)?
The number 2π is forced on us, it is the circumfrence divided by the radius. Now, Janus says this in his post but I will repeat it. Take the radius, mark that length off on the arc of the circumference, the angle defined is 1 radian. This definition means that there must be 2π radians in a circle. Repeat that to yourself until it starts to make sense.
Ah..., no, I really do NOT miss Donde!
To add, the use of this natural units system makes a lot of calculations possible. Eg. calculus with trignometric functions, which is generally based on the result that: x -> 0 : sinx -> x, provided x is in radians.
Using a numberline helped me out tremendously.
Euler is the first person who started to use radian in trigonometry. The circumference of a unit circle is 2pi, therefore he defined 360 degrees be 2pi radian.
A radian is the measure of an angle subtended at the centre of a circle by an arc equal in length to the radian.
(URGENT) What does subtended mean?
What does subtended mean? I forgot and I have a test tomorrow
Subtended means spanned on the circumference between the two lines making the angle. So the arc subtended by an angle at the center of a circle means you draw the two radii that make the angle at the center of the circle, and then the smaller arc of the circumference between those two radii is the arc subtended.
Thank-you:smile: It makes it clearer although I already had my test
  • · Replies 70 ·
9K
