New Reply
Internal energy and thermodynamic entropy
Share Thread Thread Tools
Feb17-11, 07:32 AM   #1
As a practical matter, the internal energy of a system is treated as a state function of a the system and is concerned only with the kinetic energy of particles, not the potential energy. So for thermodynamic entropy, S=E/T, (S=entropy, T= absolute temperature) I'm considering E to be kinetic energy.
Now thermodynamic temperature has been defined as the average kinetic energy per unit particle. If so, we can say T=E/N where E is the internal (kinetic) energy of a system. Then, S=E/T=E/E/N=N. That is, S becomes a dimensionless number equal to (or direct function of) the number of particles in the system. The Boltzmann equation: S=k log W considers only the number of particles in a system since [tex]W=N!/\Pi N_{i}![/tex].
If S=f(N), then the entropy of a system of N particles would seem to be constant. That would mean it doesn't matter if you add or remove energy or dilute or concentrate the particles. S is always constant unless you add or remove particles. Is this true?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Feb17-11, 11:55 AM   #2
Recognitions:
Homework Helper Homework Help
Quote by SW VandeCarr View Post
This is true only of an ideal gas. It is not true of steam, for example.
This is not the definition of entropy. dS = dQ/T where dQ = dU + W = dU + PdV. In your equation E appears to be the same as U, internal energy.
This is not how temperature is defined. T is directly related to average kinetic energy of a molecule as follows:
[tex]KE_{avg} = 3kT/2[/tex]
where k is the Boltzmann constant having units of Joules/degree K
No. If you take into account what I have said above, you will avoid this confusion. S has dimensions of energy/temperature. You are equating Q with U. All you are saying that if U is proportional to T (which it is in an ideal gas) then dU/dT will be constant. That is true, but that has nothing to do with entropy. Entropy is heat flow / temperature: S = Q/T
AM
Feb17-11, 03:35 PM   #3
So you're saying:
dS=dE/T
which is fine when entropy doesn't depend on volume (zero pressure always).
Integrating both sides you get:
[tex]S=\int dE/T [/tex]
But T is a function of just E and not V (try to guess why), so it ought to be:
[tex]S=\int dE/T(E) [/tex]
But now you say that T(E)=aE, where 'a' is a proportionality constant.
Then the integral becomes:
[tex]S=\int dE/aE=\log E /a [/tex]
So your entropy depends on the log of energy. And notice that this is the result for how the entropy of a solid varies with energy in the high energy limit!
But it's not quite the exact result. The reason is that T is proportional to E only at high energies, whereas in the integral you assumed T is proportional to E even at low energies. But still the integral gives an accurate result when you have a lot of energy, since the integral is dominated by this high energy region (since this region is large), and a few inaccuracies at the beginning of the integral don't matter.
Feb18-11, 05:20 AM   #4
Quote by Andrew Mason View Post
Thank you for your response. Yes. I'm really asking my question in terms of an ideal gas. I want to avoid the specific interactions which occur between particles. I want to consider the case where the specific heat a of a gas (J/kmol) is constant (or nearly so )over some range of temperature.
This doesn't appear to change the situation of interest since you are only multiplying the variable T by a constant.
The Boltzmann equation for entropy contains only one variable: N. The Gibbs equation contains only one variable: p. In the first case N is the number of particles in the system, In the second case p is the probability of a particular position-momentum phase state configuration of N particles at equilibrium.
My question is: Given that dU/dT is constant in an ideal gas, can we say that [tex]U=k(mv^2/2)[/tex] in an ideal gas? In other words, in an ideal gas, does entropy only depend on the number of particles: N?
Feb18-11, 07:37 AM   #5
Recognitions:
You seemed to be interested in making the point that entropy is dimensionless. Temperature has units of kelvins which is not the same as energy.
The Boltzmann equation for entropy contains only one variable: N. The Gibbs equation contains only one variable: p. In the first case N is the number of particles in the system.
This is not correct. N is the number of microstates that the collection of molecules can have. It is usually written using the symbol [itex]\Omega[/itex] to avoid confusion with N being the number of molecules. The number of microstates depends upon volume and the molecular speed as well as the number of molecules. It would also depend on the orientation of those molecules if they are not monatomic.
In the second case p is the probability of a particular position/momentum phase state configuration of N particles at equilibrium.
Which, again, depends upon the number of available microstates.
No. [itex]U = Nmv_{rms}^2/2 = 3NkT/2[/itex]. And this is true only for a monatomic ideal gas since single atoms have only 3 degrees of freedom.
For the above reasons the answer is no.
AM
Feb18-11, 09:31 AM   #6
See: http://hyperphysics.phy-astr.gsu.edu...entropgas.html
for the entropy of an ideal gas. It contains lots of variables besides N. Notice how it varies with energy as a log. T=(2/(3NK))E for a monotone ideal gas, so you would plug in "a"=2/(3NK)
in the equation:
[tex]S=\frac{log E}{a} [/tex]
For an ideal gas you need to include volume. For a solid volume is not really important. As long as energy is proportional to temperature, you'll get an entropy dependence on energy as a log.
Feb18-11, 01:55 PM   #7
Quote by RedX View Post
in the equation:
Thanks for the link. I would note that in your expressions, N is the only variable in the relation between T and E. So [tex]S=\frac{log E}{a}[/tex] should be equivalent to Boltzmann's [tex]S=k. log. W[/tex] and Gibbs'[tex] S=-k\sum p_{i}. log.p_{i}[/tex].
Feb18-11, 03:48 PM   #8
Recognitions:
That is not what Redx said. He said that [tex]S=\frac{log E}{a}[/tex] does not take into account changes in volume whereas the correct equations do.
[tex]\Delta S = \int dQ/T = \int dU/T + \int PdV/T[/tex]
For a monatomic ideal gas dU = nCvdT = 3NkdT/2, and with no change in volume (PdV = 0) over a reversible path between states i and f:
[tex]\Delta S_{i-f} = \int_{T_i}^{T_f} dU/T = 3Nk/2\int_{T_i}^{T_f} dT/T = \frac{3Nk}{2}\ln\left(\frac{T_f}{T_i}\right)[/tex]
Since T = 2U/3Nk, we have:
[tex]\Delta S = \frac{3Nk}{2}\ln\left(\frac{U_f}{U_i}\right)[/tex]
Caution: this is only true if there is no change in volume over a reversible path between the two states i and f.
AM
New Reply
Thread Tools
Similar Threads for: Internal energy and thermodynamic entropy
Thread Forum Replies
Thermodynamic Potentials - Internal energy problem. Introductory Physics Homework 0
Thermodynamic cycle and entropy Classical Physics 2
Entropy and internal energy Introductory Physics Homework 6
Entropy, Adiabatic Conditions and Internal Energy Introductory Physics Homework 0
Internal energy vs. Enthalpy vs. Entropy Advanced Physics Homework 6
