Can a single photon take any path to a detector despite barriers?
  • Context: Graduate
  • Thread starter Thread starter primal schemer
    Photon Travel
The discussion revolves around the behavior of a single photon emitted from a light source and its detection by a machine, particularly focusing on the paths the photon can take to reach the detector and the implications of barriers in its path. The scope includes conceptual inquiries into quantum mechanics and the nature of light propagation.
  • One participant questions whether a photon can only be detected in a specific area relative to the light source, suggesting that it can take any path to the detector.
  • Another participant proposes that while all paths are possible, alternative routes cancel each other out, leading to the appearance of straight-line travel for light.
  • A different participant notes that removing possible routes with barriers, such as a thin slit, allows light to be observed traveling in different directions.
  • One participant introduces a hypothetical scenario involving a vacuum chamber made of photon detectors, prompting further inquiry into the implications of such a setup.
Participants generally agree that all paths are possible for a photon, but there is no consensus on the mechanisms behind why certain paths cancel out or how barriers affect photon travel. The discussion remains unresolved regarding the specifics of these phenomena.
Participants express uncertainty about the underlying physics of photon behavior, particularly in relation to barriers and path cancellation. There are references to concepts that may require further clarification or exploration.
primal schemer
Hi All,
Just wondering about something. First of all, if I have a light source that emits a single photon at a time, and a machine that can detect photons, am I right in assuming that the photon can only be detected by the detecting machine in one area. For example if the light source is in the middle of the room, pointing left, then the detection machine must be on the left hand side of the room, "looking at" the light source in order to detect the photon??
If this is correct, am I also right in saying that the photon can take any path from the light source to the detector, and that while the probabity is huge that it will go in a straight line to the detector, it may follow any path?
Ok, 2 questions. Firstly, Why can it go in any path?? (I think that this is an unanswered question in physics, but I thought I`d ask it anyway)
And secondly, I read somewhere (can`t recall where) that all paths cancel each other out to ensure that light almost always travels in the straight line. How does this happen?
Now, another scenario for the same setup. This time in between the light source and the detector, there is a barrier with only a tiny gap directly in between the source and the detector (that is you can draw a straight line between the source and the detector through the gap). Light now doesn`t travel in a straight line (you would have to move the detector down to detect it). Is this because all other possible paths cannot cancel each other out (due to the barrier)?? or is there some other reason.
Help appreciated,
Primal schemer
Hmm, very interesting questions, for the second I think you are mixing up with electricity; electricity takes all paths there. This may be due to the whole electromagnetic force, photon and electron thing. :biggrin: Hope I could help.
All paths are indeed possible, but as you say, the 'alternative routes' cancel out, making light appear to go in straight lines.
If you remove some of the possible routes with a thin slit or a diffraction grating, the light can be seen to go in different directions.
(Feynman's QED is the best book you can get if you want to understand this further.)
Well, if you had a vacuum chamber the width of one photon, and however long you want, and the chamber was made of the photon detectors, then what would come up?
  • · Replies 16 ·
  • · Replies 0 ·
  • · Replies 18 ·
  • · Replies 18 ·
  • · Replies 81 ·
