New Reply
Vacuum chamber design
Share Thread Thread Tools
Feb19-11, 02:08 AM   #1
I work with some samples that are dissolved in ethanol. Currently, we plate them, and evaporate overnight in a fume hood, and then bake them using a standard convection lab oven. It takes about 24 hours and really slows me down.
And buying an explosion proof vacuum oven is ridiculously expensive. I've been quoted $40-50,000 for "table top" units.
So, I figure, I'm a mechanical engineer... I could just build me one.
But I've never designed a vacuum chamber. How do I go about it? I know the myth of "just build it thicker" is a bad.
Ideally, what I'd like is a square box, with 4 walls, and a bottom that's 12" x 12" x 12". The top would be a 14" square, with a gasket that could be laid on top of the box, closing it. and I've had 2 ports on the side of the box, one for a vacuum break valve, and another for the vacuum line to hook up to.
My vacuum pump is a 3-4 CFM air operated vacuum pump. It's capable of 25" of Hg vacuum.
I can externally heat the box with an intrinsically safe hot plate, or steam source.
I'd appreciate some help, or a lot of help, with attacking this project.
Thanks everyone.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
New Reply
Thread Tools
Similar Threads for: Vacuum chamber design
Thread Forum Replies
Plenum Chamber Design Engineering Systems & Design 25
Creating a heated Vacuum chamber. Materials & Chemical Engineering 3
Vacuum chamber General Physics 4
Vacuum system design Engineering Systems & Design 5
Centrifugal force for supporting vacuum chamber walls? General Physics 17
