Differential equation integrating factor conceptual question.
The discussion centers on the concept of integrating factors in differential equations, specifically addressing the omission of absolute values in integration. The integrating factor is defined as either 1/x or -1/x, depending on the restriction of x to positive or negative values. Both choices yield equivalent solutions when applied to the differential equation, demonstrating that the absolute value is unnecessary in this context. The continuity of 1/x at x=0 is highlighted as a critical factor in determining the appropriate integrating factor.
  • Understanding of differential equations
  • Familiarity with integrating factors
  • Knowledge of continuity and discontinuity in functions
  • Basic calculus concepts, including integration
  • Study the properties of integrating factors in differential equations
  • Learn about continuity and discontinuity in mathematical functions
  • Explore examples of differential equations with different integrating factors
  • Review the implications of restricting variable domains in calculus
Students and educators in mathematics, particularly those studying differential equations, as well as anyone seeking to deepen their understanding of integrating factors and their applications.
td21
Sorry asking similar quesion again about absolute value. You can read the attachment.
u(x) is the integrating factor. Why absolute value is omitted in the integration? and why the integrating factor is not "1/|x|", with the absolute sign
i thought we must use the abs sign and the solution is wrong?
The answer is exactly the same as to the question you asked in
https://www.physicsforums.com/showthread.php?t=474430
Since 1/x is not continuous at x= 0, it cannot be "continued" across x= 0. We must choose to restrict x to be positive or negative. If we choose to restrict x to be positive, we have 1/x. If we choose to restrict x to be negative, we have -1/x.
Since you use the integrating factor by multiplying the entire equation by it, you will get the same solution either way:
Taking the integrating factor to be 1/x, we get
[tex]\frac{1}{x}\frac{dy}{dx}- \frac{y}{x^2}= \frac{d}{dx}\left(\frac{1}{x}y\right)= 2+ \frac{1}{x}[/tex]
Taking the integrating factor to be -1/x, we have
[tex]\frac{-1}{x}\frac{dy}{dx}+ \frac{y}{x^2}= -\frac{d}{dx}\left(\frac{1}{x}y\right)= -2- \frac{1}{x}[/tex]
But multiplying both sides of that equation by -1 gives the same as the first equation.
