Derivative of Ln(x): Domain Restriction & Antiderivative
  • Context: Undergrad
  • Thread starter Thread starter SprucerMoose
    Derivative
The discussion revolves around the derivative and antiderivative of the natural logarithm function, specifically ln(x) and ln(x + 1), as well as the conditions under which definite integrals can be calculated for functions that may not be differentiable across their entire interval. The scope includes theoretical aspects of calculus and integration rules.
  • Technical explanation, Conceptual clarification, Debate/contested, Mathematical reasoning
  • One participant questions whether the domain of ln(x + 1) should be restricted to x > -1 to avoid issues with the antiderivative resulting in ln|x + 1|.
  • Another participant asserts that the domain of definition for functions must always be specified when integrating or differentiating.
  • A participant inquires about the possibility of calculating a definite integral over an interval where the function is continuous but not differentiable, using ln|x| + 5 as an example.
  • One participant points out that ln|x| + 5 is not continuous over [-1, 1] due to a discontinuity at x = 0, suggesting that continuity is necessary for integrability.
  • Another participant mentions that continuity on [a, b] implies the existence of the definite integral over that interval, providing examples of functions that are continuous but not differentiable.
  • There is a discussion about the necessity of splitting the integration interval when the argument of an absolute value function changes sign.
Participants express differing views on the implications of continuity and differentiability for definite integrals, and there is no consensus on the necessity of domain restrictions for the logarithmic functions discussed.
Participants highlight the importance of specifying domains and continuity conditions, but there are unresolved questions regarding the implications of these factors on integration and differentiation.
SprucerMoose
Hey guys,
I just have a quick question about the derivative of ln(x). If i was to calculate the derivative of ln(x +1) = 1/(x+1), would I technically have to restrict the domain of the solution to x>-1?
Otherwise when I take the antiderivative again, I will have Ln|x+1| (note the absolute value) and not the original function.
One other question that I sort of implied to be fact, if i take the integral of 1/x, where x>0, is the solution now Ln(x) rather than Ln|x|?
Yes to all your questions. Rigorously speaking, the domain of definition for the functions being integrated or differentiated must always be specified.
Thanks for the quick response.
By the way can a definite integral be calculated across an interval where the function is continuous, but not differentiable for the entire interval?
ie. http://latex.codecogs.com/gif.latex?\int_{-1}^{1}(ln|x|+5) dx
I'm not talking about splitting the interval to calculate the area, if that is what would be done, I'm more interested in the specific rules for a definte integral.
The function ln|x|+5 is not continuous in the interval [-1,1], so it is not illustrative of your question. There is a discontinuity at x=0.
I'm pretty sure every function is integrable over any range in which it is continuous. A better example, for you question, would be to integrate y=x1/3 over some range that includes x=0, since this function is continuous but not differentiable at x=0.
Oops, I meant
Sure, when you take a course in real analysis, you'll learn that continuity on [a,b] implies that the definite integral on [a,b] exists.
A simple example would be [tex]\int_{-1}^1 | x| \, dx[/tex] which is continuous but not differentiable at 0. A more satisfying example would be the Weierstrass function which is continuous but nowhere differentiable.
SprucerMoose said:
Oops, I meant
Okay, understood.
The only rule I can think of is: whenever the argument of an absolute value function changes sign, you must split the integration interval at that (those) point(s). We can't come up with an analytic form for integrating |f(x)| without doing that.
