Confusion on orientation of manifolds
The discussion centers on the orientation-preserving parametrization of manifolds as defined in "Vector Calculus, Linear Algebra, and Differential Forms: A Unified Approach" by John Hubbard and Barbara Hubbard. The user highlights a contradiction in the book regarding the orientation of a torus parametrized by γ(u,v) = ((R+rcos u)cos v, (R+rcos u) sin v, rsin u). While the book asserts that if the cross product n(x) = D1γ X D2γ is used, the orientation should be preserved, the example shows that at the point γ(0,0), the normal vector points inwards, indicating a failure to preserve orientation. This contradiction raises confusion about the conditions under which orientation is maintained.
  • Understanding of manifold theory and parametrization
  • Familiarity with vector calculus, particularly cross products
  • Knowledge of determinants and their properties
  • Basic concepts of differential forms and orientation in R^3
  • Study the properties of orientation in manifolds using "Vector Calculus, Linear Algebra, and Differential Forms" by Hubbard
  • Learn about the implications of the cross product in determining surface orientation
  • Explore examples of parametrizations of different manifolds and their orientations
  • Investigate the relationship between tangent vectors and orientation preservation in higher dimensions
Mathematicians, students of differential geometry, and anyone studying the properties of manifolds and their parametrizations will benefit from this discussion.
demonelite123
my book defines an orientation preserving parametrization of a manifold as one such that:
Ω(D1γ(u), ..., Dkγ(u)) = +1 for all u in the domain of γ, where D1,...Dk are the derivatives of the parametrization γ.
my book also defines the orientation of a surface in R^3 by Ω(v1,v2) = sgn det[n(x), v1, v2] where sgn takes the sign off a real number and n(x) is a transverse vector field and v1 and v2 form a basis for the tangent space of the surface at the point x. if we choose n(x) to be D1γ X D2γ (the cross product) then Ω(D1γ, D2γ) = sgn det[D1γ X D2γ, D1γ, D2γ] and it is simple to show that this determinant is > 0 for all input values. then by the first definition stated above, if you choose n(x) = D1γ X D2γ, then γ must preserve the orientation of the surface in R^3.
however my book seems to contradict itself when it gives an example. let M be the torus obtained by choosing R>r>0 and taking the circle of radius r in the (x,z) plane that is centered at x = R and z = 0 rotating it around the z axis. assume it is orientated by the outward pointing normal. does γ(u,v) = ((R+rcos u)cos v, (R+rcos u) sinv, rsin u)) preserve the orientation?
my book went on to calculate D1γ and D2γ as well as D1γ X D2γ and letting n(x) = D1γ X D2γ. my book presented a proposition right before this example that said if γ preserves orientation at a single point in U (domain of γ) then it preserves orientation at every point of U. the book calculated n = D1γ X D2γ at the point γ(0,0) and got n = -r(r+R)[1, 0, 0] (column vector). which it then says points inwards and thus does not preserve orientation. i am confused because earlier the book said that if you chose n = D1γ X D2γ then it will preserve orientation. any help is clearing up this matter is greatly appreciated.
im a little confused too. what book is it?
Vector Calculus, Linear Algebra, and Differential Forms: A Unified Approach - John Hubbard, Barbara Hubbard
