Magnetic field of a lightning bolt
The magnetic field generated by a lightning bolt can be calculated using Ampere's law. In this case, 14 C of charge flows over a duration of 1.5 x 10^-3 seconds, resulting in a current (I) of approximately 9333.33 A. By applying the formula B = (μI)/(2πr), where μ is the permeability of free space (4π x 10^-7 T·m/A) and r is the distance from the bolt (27 m), the magnitude of the magnetic field is determined to be 1.48 x 10^-4 T. This value indicates that while lightning produces strong electric fields, its magnetic fields are comparatively weaker.
  • Understanding of Ampere's law
  • Basic knowledge of electric charge and current
  • Familiarity with the concept of magnetic fields
  • Knowledge of the permeability of free space (μ)
  • Study the applications of Ampere's law in various electromagnetic scenarios
  • Explore the relationship between electric fields and magnetic fields in lightning
  • Investigate the effects of lightning on surrounding environments
  • Learn about the properties of electromagnetic waves generated by lightning
Physicists, electrical engineers, meteorologists, and anyone interested in the electromagnetic phenomena associated with lightning.
1timeuse
In a lightning bolt, 14 C of charge flows in a time of 1.5 x 10^-3 s. Assuming that the lightning bolt can be represented as a long, straight line of current, what is the magnitude of the magnetic field at a distance of 27 m from the bolt?
do i use 27 m as the radius in the equation
[tex]B = \frac {\mu I}{2\pi r}[/tex]
Yes! That's just Ampere's law applied to a cylindrically symmetric current.
Yes, you would use 27 m as the distance (r) in the equation. The magnitude of the magnetic field can be calculated as follows:
B = (4π x 10^-7 T·m/A) x (14 C / 1.5 x 10^-3 s) / (2π x 27 m)
B = 1.48 x 10^-4 T
Therefore, the magnitude of the magnetic field at a distance of 27 m from the lightning bolt is 1.48 x 10^-4 T. This is a relatively small value, as lightning bolts typically have very strong electric fields but weaker magnetic fields.
13K
