Mass spectrometer radius of the path
The radius of the path for doubly ionized gold ions (Au2+) in a mass spectrometer can be calculated using the formula r = √(2mV) / (2qB²). In this case, the mass of the ions is 3.27 x 10^-25 kg, they are accelerated through a potential difference of 1.40 kV, and subjected to a magnetic field of 0.600 T. The charge of the ions is 2 times the fundamental charge, resulting in q = 3.2 x 10^-19 C. The calculated radius of the path is approximately 1.7 cm.
  • Understanding of mass spectrometry principles
  • Familiarity with the concepts of electric potential and kinetic energy
  • Knowledge of magnetic fields and their effects on charged particles
  • Ability to perform calculations involving physical constants and units
  • Learn about the principles of mass spectrometry and its applications
  • Study the relationship between electric potential and kinetic energy in charged particles
  • Explore the effects of magnetic fields on the motion of charged ions
  • Investigate advanced calculations involving ion trajectories in varying magnetic fields
Students and professionals in physics, particularly those studying or working with mass spectrometry, as well as researchers involved in ion analysis and related fields.
1timeuse
Suppose that an ion source in a mass spectrometer produces doubly ionized gold ions (Au2+), each with a mass of 3.27 x 10^-25 kg. The ions are accelerated from rest through a potential difference of 1.40 kV. Then, a 0.600 T magnetic field causes the ions to follow a circular path. Determine the radius of the path.
i tried to use
[tex]r = \frac {\sqrt{2mV}}{2q B^2}[/tex]
i doubled the q because the question says the ions are doubly ionized. is q = 1.6 e -19 still or is it different with gold ions? my answer was 7.95 e -3 but I'm wrong according to my webassign.
i tried to use
Your denominator also belongs under the radical.
The formula you used, r = \frac {\sqrt{2mV}}{2q B^2}, is the correct one to use for finding the radius of the path of the ions in a mass spectrometer. However, the value of q will change depending on the charge of the ion. In this case, since the gold ions are doubly ionized, the charge would be 2 times the fundamental charge, so q = 2(1.6 x 10^-19) = 3.2 x 10^-19 C.
Plugging in the given values, we get:
r = \frac {\sqrt{2(3.27 x 10^-25)(1.40 x 10^3)}}{2(3.2 x 10^-19)(0.600)^2} = 0.017 m or 1.7 cm
So the radius of the path of the gold ions in this mass spectrometer would be approximately 1.7 cm. Make sure to double check your calculations and units to ensure accuracy.
18K
