Triginometry: Half Angle Identities
  • Thread starter Thread starter StephenAA
    Angle identities
The discussion revolves around finding the value of sin(75°) using half-angle identities in trigonometry. Participants explore the application of the half-angle formula and its simplification, while also considering alternative methods such as the sum formula for sine.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the use of the half-angle identity and express uncertainty about the simplification process. Some question whether the plus-minus sign is necessary and explore the implications of quadrant considerations on the sign of the sine value.
The discussion is active, with participants providing hints and guidance on simplification techniques. There is a recognition of the need to clarify the use of the plus-minus sign, and some participants express increased clarity regarding the simplification process as a result of the discussion.
Participants note that the problem specifically requests the use of half-angle identities, which may limit the approaches considered. There is also mention of the importance of understanding the quadrant in determining the sign of the sine value.
StephenAA
[tex]sin(75^\circ)[/tex]
[tex]sin(\frac{\alpha}{2}) = \pm \sqrt{\frac{1-cos(\alpha)}{2}}[/tex]
The answer is known to be:
[tex]\frac{\sqrt{6} + \sqrt{2}}{4}[/tex]
[tex]sin(\frac{150^\circ}{2}) = \pm \sqrt{\frac{1-cos(150^\circ)}{2}}[/tex]
[tex]sin(\frac{150^\circ}{2}) = \pm \sqrt{\frac{1+\frac{\sqrt{3}}{2}}{2}}[/tex]
[tex]sin(\frac{150^\circ}{2}) = \pm \sqrt{\frac{2+\sqrt{3}}{4}}[/tex]
[tex]sin(\frac{150^\circ}{2}) = \pm \frac{\sqrt{2+\sqrt{3}}}{2}[/tex]
This is a correct answer, but clearly it is not simplified completely. Any help would be appreciated.
Are you supposed to use the half-angle identity? Think of another way to figure it out.
Hint: Sum Formula for sin function.
Yes. As you stated, this problem can be solved easily with the sum formula for sin, but the directions ask us specifically to solve it using half angle identities. My problem is that I get stuck at that last step, as I'm not quite sure how to simplify it further.
First off, do we NEED the plus-minus sign? (If not, can you explain why not?)
The 2nd to last line you have this:
Inside the square root, multiply top and bottom by 4. Factor out a 2 in the numerator (not 4!). You should have
[tex]\sin \left(\frac{150^\circ}{2}\right) = \sqrt{\frac{2(4 + 2\sqrt{3})}{16}}[/tex]
Split the 4 into 1 + 3:
[tex]\sin \left(\frac{150^\circ}{2}\right) = \sqrt{\frac{2(1 + 2\sqrt{3} + 3)}{16}}[/tex]
This expression:
[tex]1 + 2\sqrt{3} + 3[/tex]
is an algebraic pattern that's somewhat disguised. See if you can figure out the rest.
I'm not entirely sure how to determine whether the answer should be positive or negative (the quadrant, perhaps?), so I just left it there.
Anyways, thanks for your help. It's much more clear now.
[tex]sin(\frac{150^\circ}{2}) = \pm \sqrt{\frac{8+4\sqrt{3}}{16}}[/tex]
[tex]sin(\frac{150^\circ}{2}) = \pm \sqrt{\frac{2(4+2\sqrt{3})}{16}}[/tex]
[tex]sin(\frac{150^\circ}{2}) = \pm \sqrt{\frac{2(1+2\sqrt{3}+3)}{16}}[/tex]
[tex]sin(\frac{150^\circ}{2}) = \pm \sqrt{\frac{2(1+\sqrt{3})^2}{16}}[/tex]
[tex]sin(\frac{150^\circ}{2}) = \pm \frac{(\sqrt{2})(1+\sqrt{3})}{4}[/tex]
For the final answer:
[tex]sin(75^\circ) = \pm \frac{\sqrt{2}+\sqrt{6}}{4}[/tex]
Or, as the answer key lists it:
[tex]sin(75^\circ) = \pm \frac{\sqrt{6}+\sqrt{2}}{4}[/tex]
Thank you for your help.
Yes, but not quite. sin(75o) is a positive value, so you need to discard the negative value.
