Maximizing Oil-in-Water Separation: Tips for Efficient Drying Methods
  • Thread starter Thread starter fourdegreesc
    Separation
The discussion focuses on efficient methods for drying emulsified vegetable oil in a small chamber at 60°C. Key techniques highlighted include vacuum dehydration, specifically flash distillation vacuum dehydration and mass transfer vacuum dehydration. Participants recommend using a centrifuge as a preliminary step to remove most of the water before applying vacuum methods, as it is a cost-effective solution. The use of absorbent filters, draining, and coalescers are also suggested as complementary techniques for optimal water removal.
  • Understanding of vacuum dehydration techniques
  • Familiarity with centrifuge operation and applications
  • Knowledge of emulsification processes in chemistry
  • Experience with drying technologies in chemical engineering
  • Research flash distillation vacuum dehydration methods
  • Learn about mass transfer vacuum dehydration techniques
  • Explore the operation and benefits of centrifuges in liquid separation
  • Investigate the use of absorbent filters and coalescers in oil processing
Chemists, chemical engineers, and professionals involved in oil processing and separation techniques will benefit from this discussion.
fourdegreesc
Try not to fly too far over my head if you answer this. I'm just an amateur chemist who spent three years in the chemistry department until I hit a wall (Calculus!) and ended up with a writing degree. So be gentle please.
I'm trying to dry oil (vegetable oil) in a process (rather than a batch). It will be in a tiny chamber, maybe as big as your fist, and it will go down at 60C, so I was thinking of pulling a vacuum on the chamber to flash off the water. The chemistry question goes like this:
If the water is emulsified in the oil, will it flash off?
I have experience building evaporative processes, as I built my own desalinator, so I'm biased to this technique. I have already figured out the kinks of it.
Any advice will help. Thanks!
-dennis
Chemistry news on Phys.org
To get most of the water you want to use a centrifuge first and then follow that with your method or a different drying technology as Nucleus suggests. Centrifuging is a lot cheaper than making vacuum so use it to do most of the work.
9K
  • · Replies 28 ·
  • · Replies 19 ·
11K
