| New Reply |
Molarity of Copper Ion solution produced from Copper, Nitric Acid, and Water |
Share Thread | Thread Tools |
| Feb26-11, 09:55 PM | #1 |
(c) A 0.1036 g sample of copper metal is dissolved in 48 mL of concentrated HNO3 to form Cu2+ ions and then water is added to make a total volume of 208.1 mL. (Calculate the molarity of Cu2+.) 2. Relevant equations Molarity = Moles/Liter 3. The attempt at a solution .1036g/63.55g/mol = .0016302124 moles .0016302124/.2081 (moles of Copper Ions over final Volume in liters) = .0078337935 M - webassign says this is wrong. I'm thinking perhaps the reaction between copper metal and HNO3 to yield Cu2+ ions isnt 1:1 in stoichiometry and maybe i have to balance the equation and use oxidation states to get it right but i have no idea how to approach balancing this reaction because i'm not even clear what the products are and then i'm not sure if water does anything additional to the solution besides add volume, maybe some other reaction happens? thx The molarity they want is the molarity of Cu2+ |
| Feb26-11, 10:12 PM | #2 |
nvm - my answer is correct but webassign was being retarded and inconsistent with significant figures, as it often is. thx anyway
| Feb26-11, 10:16 PM | #3 |
Recognitions:
The balancing is not necessary. Copper metal, all converted to Cu+2.
How many moles of Cu? How much volume of final solution as liters? Calculate moles Cu in 1 liter. That is your molarity of Cu (in your example, as Cu+2 ions.) Is your webassign expecting correct accuracy for the given values? You showed too many significant figures in your work. (Just finished writing my message while torquemada's post was made.) |
| Feb26-11, 10:19 PM | #4 |
oh ok hehe
| New Reply |
| Thread Tools | |
Similar Threads for: Molarity of Copper Ion solution produced from Copper, Nitric Acid, and Water
| How to stabilize copper oxide on acrylic acid copolymers | Chemistry | 0 | ||
| Calculating the mass of carbon needed to reduce 15.9g of Copper(II) Oxide to Copper | Biology, Chemistry & Other Homework | 2 | ||
| Modification of Copper & Copper Alloys | Materials & Chemical Engineering | 4 | ||
| How do I remove copper from water (be realistic) | Chemistry | 5 | ||
| Copper Nitrate plus water | Chemistry | 11 | ||
