Angular velocity of a conical pendulum in rpm
The discussion centers on calculating the angular velocity of a conical pendulum with a 0.900 kg mass attached to a 1.00 m string, moving in a horizontal circle with a radius of 20.0 cm. The user initially calculated the angle θ as 78.46 degrees and derived a tangential velocity of 6.86 m/s, leading to an angular velocity of 327.5 rpm. However, this result was identified as incorrect, prompting a suggestion to re-evaluate the angle calculation.
  • Understanding of conical pendulum dynamics
  • Familiarity with angular velocity and its conversion to rpm
  • Knowledge of trigonometric functions, particularly sine and cosine
  • Proficiency in applying Newton's laws of motion
  • Review the derivation of the angle θ in conical pendulum problems
  • Learn how to correctly apply the formula for tangential velocity in circular motion
  • Explore the relationship between angular velocity and linear velocity
  • Practice similar problems involving conical pendulums and angular velocity calculations
Students studying physics, particularly those focusing on mechanics and circular motion, as well as educators seeking to clarify concepts related to conical pendulums.
kerbyjonsonjr
A conical pendulum is formed by attaching a 0.900 kg ball to a 1.00 m long string, then allowing the mass to move in a horizontal circle of radius 20.0 cm . What is the ball's angular velocity, in rpm?
v=[tex]\sqrt{}L*g*sin(\vartheta)*tan(\vartheta)[/tex]
w=v/r
Since the radius is .2 m and the length of the string is 1m I used cos([tex]\vartheta)[/tex] and found [tex]\vartheta[/tex] to be 78.46 degrees. Then I used that equation for tangential velocity so I had v=[tex]\sqrt{}1*9.81*sin(78.46)*tan(78.46)[/tex] and got v=6.86 m/s so then I used w=v/r and got w=34.3 rad/sec which I then converted to rpm by multiplying 34.3 by 60 seconds times 1 rev/2[tex]\pi[/tex] and got 327.5 rpm and that is wrong. I don't know where I went wrong. I greatly appreciate any help.
w=v/r
I don't think you have the right angle. Double check how you got that.
