Where can I find a schematic for a DIY component to VGA adapter?
A schematic for a DIY component to VGA adapter is sought for connecting a PS3 to a monitor. The discussion highlights the importance of understanding the monitor's support for YPbPr and RGB outputs. If the monitor supports synch-on-green and HDTV resolutions, a straightforward connection can be made: Y to green, Pr to red, Pb to blue, and ground to ground. The distinction between RGB and YPbPr color spaces is emphasized, explaining the high cost of commercial adapters.
  • Understanding of YPbPr and RGB color spaces
  • Knowledge of VGA signal connections
  • Familiarity with PS3 output settings
  • Basic electronics skills for DIY projects
  • Research VGA signal specifications and pin configurations
  • Learn about PS3 video output settings and configurations
  • Explore DIY electronics resources for creating video adapters
  • Investigate the differences between RGB and YPbPr color spaces
Engineering students, DIY electronics enthusiasts, and anyone interested in creating custom video adapters for gaming consoles.
Shadow787470
Component to VGA schematic??
Anyone know where i can find a schematic for a component to VGA adapter? A friend is looking to make one so he can use his ps3 on his monitor but says most of the store bought ones are quite expensive and have lots of extra features. We are both engineering majors so making one seems logical. He has done a bit of research but wasnt able to find a simple component to vga diagram.
Does the monitor support YPbPr? Or can the PS3 be set to output RGB and does the monitor support synch-on-green and HDTV resolutions? If so, then it's a simple matter of connecting Y to green, Pr to red, Pb to blue, and ground to ground.
Otherwise, you're out of luck. RGB and YPbPr are different color spaces. There is a reason those adapters are expensive.
108K
  • · Replies 19 ·
