| New Reply |
Very simple question regarding work and energy transfer |
Share Thread | Thread Tools |
| Mar2-11, 10:19 PM | #52 |
Very simple question regarding work and energy transferEdit: Yes, I am asking you. This is a 2 way conversation and I don't know what you know compared to me. It is entirely possible you or I have the wrong idea about work and force and energy, and the only way to tell is to talk! |
| Mar2-11, 10:26 PM | #53 |
For me pressing muti quote then quote, or pressing quote, are producing the same result. One long quote of the entire post rather than each paragraphe being a quote which i can then comment on. I'm obviously doing something wrong. Any suggestions?
| Mar2-11, 10:27 PM | #54 |
Press the multi quote for each post you want to quote, then hit New Reply, not quote.
| Mar2-11, 10:40 PM | #55 |
Mentor
| Mar2-11, 10:43 PM | #56 |
I think everything can be explained in terms of energy.
To simplify things, potential energy converts to kinetic energy, that's easy. When the object hits the earth, almost all of the kinetic energy ultimately gets converted to heat, because the object is no longer moving. That's easy too. The question of what are steps by which the kinetic energy gets converted to heat, that's the complicated part. Following where the energy goes from the time the object first touches the earth, until the collision is complete, is complicated. Lets ignore all the small contributions: 1) Energy which deforms the Earth - If the Earth were elastic, but not rigid, it would absorb some of the energy and give it back to the object. If the Earth were elastic and perfectly rigid, it would absorb no energy, but it still would exert a force on the object. 2) Sound energy - A small amount of energy is lost in sound waves, which ultimately dissipate in the atmosphere as heat. I think this about covers the energy lost by the object to other systems. That means most of the kinetic energy conversions to heat occur in the object as it collides with the Earth. Here are my ideas about the mechanisms by which the kinetic energy is converted to heat in order of importance, assuming the object is a human body. Please add to the list, I'm sure I am forgetting some. 1) Broken atomic bonds - tearing and breaking of things. Think of this as a spring that you stretch until it snaps. You add energy to it, it holds it as potential energy, the spring snaps, it vibrates but the vibration is damped, and all that potential energy goes to heat. During the collision, the energy added is due to the force of the Earth on the contact part of the object, then force transmitted to the part above it, etc. 2) Internal pressure waves or sound waves (compression and shear) which dissipate to heat. 3) Inelastic rearrangement of parts. This is what I was modeling as an inelastic spring, one that compresses, but does not bounce back. The permanent compression holds no potential energy - the energy that went into the compression was not used to bounce the spring back, but was rather dissipated as heat. 4) Permanent elastic deformation - Parts of the body may act as springs which are compressed, do not lose their stored potential energy as heat, but are prevented somehow from springing back. Like a bone that gets bent and lodged between two other bones or something. This is energy that is not converted to heat. I think this contribution is quite small. |
| Mar2-11, 10:45 PM | #57 |
1. When work is described as the means by which energy is transferred from one object or system to another. And W=Fd. The bowl accumulates KE during its fall. The ground possesses no mechanical energy: KE+GPE+SE=0. Thus, the bowl has the capacity to do work on the ground but the ground does not have the capacity to do work on the bowl, unless, the work done by the bowl on the ground transfers its KE to the ground in the form of SE which is then transferred back to the bowl resulting in damage. (I'm still working on RAP's expanation). However, there is conflicting opinion as to whether or not the ground does work on bowl. Some suggest the work is internal to the bowl. Bottom line, I'm looking to understand the application of work in this context in terms of the transfer of energy only. 2. From a force perspective, easy peasy. W=Fd and Newton's third law. Bowl applies force to floor which applies reaction force in turn. Bowl deforms so work is done on bowl by floor. This is where it gets a bit tricky. The floor does not deform so no work is done on the floor. However, Crowell explained that if work is done on one object, work is also done on another. If no displacement of the floor ...? See above as regards to infintessimal deformation and transfer. I keep on getting caught up with the transfer of energy, and this is the concept I am interested in. Thanks |
| Mar2-11, 10:46 PM | #58 |
| Mar2-11, 11:04 PM | #59 |
If you're interested in the application of mechanics to study injury and teh causes of injury, search for William Haddon, who is the so-called father of this field. Once he conceptualised injury in terms of 'energy exchange' he was appointed to a new office in the US government responsible for road safety. Your last paragraph encaptulates my problem. KE is pre-impact, force is impact, in the three phases of an injury event. Given the definition of injury in terms of energy exposure, exchange, or transfer, I'm then attempting to reconcile any impact explanation with the initional pre-impact injury causeing energy. |
| Mar2-11, 11:09 PM | #60 |
Now comes the hard part - What are the processes by which the bowl's kinetic energy gets converted to heat? This is what we should concentrate on. The confusion results from not knowing whether a perfectly rigid Earth is being assumed or not. |
| Mar2-11, 11:21 PM | #61 |
Mentor
| Mar2-11, 11:30 PM | #62 |
1. 'The earth has the capacity to do work'. Energy is defined as the capacity to do work. What form of energy does the earth have which then has the capacity to do work? 2. I understand the idea that the reaction force applied by the earth causes displacement in terms of deformation of the bowl. The recently introduced idea that work done on one object is mirrored by work done on the other object causes me a problem. The bowl applies a force on the earth, but there is no displacement. No displacement, no work according to the most basic of texts. ... Or is that the answer. The displacement of the earth as a result of the work done on it by the bowl is so infintessimal as to approximate zero displacement. ... bugger, if so, I still come back to, if the earth does work on the bowl it transfers energy. What energy? Crowell just threw a spanner in the works in emailing me now that 'work is done on the ground.' |
| Mar2-11, 11:32 PM | #63 |
| Mar2-11, 11:40 PM | #64 |
BTW, thanks for taking the time to help me with this problem. |
| Mar2-11, 11:45 PM | #65 |
| Mar3-11, 12:14 AM | #66 |
In this case, what I think I'm left with is that upon impact no work is done, therefore no energy is transferred. The damage is explained in that the KE is not transferred but retained in teh body and converted into sound, heat, electrical, etc energy resulting in deformation, permanent deformation, and/or damage. A force has been applied by the body and the ground has applied a reaction force, and since there was no change in energy in the ground no work has been done. Now, if this is correct, all I've got to find is support for this argument as there are a number of texts which refer to the damage to body and car from an impact with a solid object or earth as being the cause of work done on it. Unless, ... I read one text which explained that 'scientists' used the terms transfer and transform to refer to the same thing. In this case, if transfer is used to refer to transfer from one form to another, the 'work done' is the transfer of KE to the other form of energy in the body. Of course I run into the problem of identifying the agents of force and reaction force in this case, given work is done on both agents. ... my head is hurting. I'm done for a while. Cheers. Thanks for the help. Instead, the KE is converted to sound, heat, and electrical energy (ignoring for the moment such specialised concepts as crystals and large area or whatever) the results in deformation, permanent deformation, and damage in the fallen body. |
| Mar3-11, 06:43 AM | #67 |
Mentor
I don't know James Gibson's background, but William Haddon was a MD, not a physicist. A MD's training is focused on medicine and not physics, and thus as a group their grasp of physics is loose at best. If you want to use that kind of loose interpretation of physics then don't expect to be able to do the kind of rigorous analysis that you seem to want, it simply won't work. |
| Mar3-11, 07:35 AM | #68 |
Recognitions:
| New Reply |
| Tags |
| energy, transfer, work |
| Thread Tools | |
Similar Threads for: Very simple question regarding work and energy transfer
| Work-Energy Theorem (Simple Question) | Introductory Physics Homework | 5 | ||
| Question about work and energy transfer | General Physics | 13 | ||
| Simple Work and Energy question | Introductory Physics Homework | 1 | ||
| Springs, Energy, Work (simple question) | Introductory Physics Homework | 2 | ||
| work transfer and energy conservation | Introductory Physics Homework | 4 | ||
