Right handed frames and Orientation
  • Context: Graduate
  • Thread starter Thread starter Buri
    Frames Orientation
The discussion revolves around the concept of "right-handed" frames and orientation in arbitrary n-dimensional vector spaces. Participants explore the definitions and implications of these terms, particularly in relation to determinants and the uniqueness of the cross product in different dimensions.
  • Some participants question the assertion that "right-handed" is not well-defined in arbitrary n-dimensional vector spaces, suggesting that a determinant function could be defined.
  • Others argue that the concepts of "greater than" and "less than" are not applicable in arbitrary vector spaces, which complicates the definition of right-handedness.
  • It is noted that "right-handed" is a term specifically associated with R^3 due to the unique properties of the associative cross product in that space.
  • Participants discuss the relationship between "right-handed" and "proper" rotations, with some expressing confusion over the distinction.
  • One participant provides a detailed explanation of how orientation is defined in n-dimensional spaces, emphasizing that in dimensions other than 3, the notion of right-handedness does not hold due to the absence of an associative cross product.
  • There is mention of an equivalence class corresponding to orientation based on the sign of a determinant, which can lead to confusion regarding the terminology used.
Participants do not reach a consensus on the definitions and implications of "right-handed" frames in arbitrary vector spaces. Multiple competing views remain, particularly regarding the applicability of determinants and the uniqueness of the cross product.
Some limitations are noted, such as the dependence on specific definitions of determinants and the choice of basis in vector spaces. The discussion highlights the complexity of these concepts without resolving the underlying mathematical ambiguities.
Buri
My text says, "Note that in an arbitrary n-dimensional vector space, there is no well-defined notion of "right-handed", although there is a well defined notion of orientation."
I don't see why. An n frame (a1,a2,...,an) is called right handed in R^n if det[a1 a2 ... an] > 0, but I guess we'd have to define a determinant function on V (though I don't think this should be a problem). However, I remember that the determinant being the only alternating n-tensor on R^n, so maybe this isn't the case in an arbitrary vector space. So we could possibly get different values depending on the determinant we use since it is no longer unique.
Any clarification?
Or is it because > 0 and < 0 aren't defined in an arbitrary vector space?
Anyone?
Your text is correct. An orthonormal matrix is a proper rotation if its determinant is one. You are confusing "right" with "proper".
"Right-handed" is special to 3 space because the associative cross product is unique to R3. (There is a non-associative cross product in R7.)
I don't understand. Could you maybe explain it a bit more? I'm just lost..
I don't see how I'm confusing "right" with "proper". I didn't even know the definition of proper till you mentioned it lol
And I thought the cross product was only defined for R^3 and besides, the definition is in terms of determinants...
Just because you didn't know that you are confusing "right-handed" (which applies only to R3) with "proper" (which applies generically) does not mean that that is exactly what you are doing.
I never said it did. If you read that correctly, I said 'I don't see HOW I'm confusing "right" with "proper" ' and the second remark, "I didn't even know the definition of proper till you mentioned it lol" was meant to show you how I really don't see how I'm confusing the two since I didn't even know the definition.
Is that even correct? Because I've been given a definition for right-handed in R^n and I'm assuming its well defined (because otherwise I would think its useless), but I think you're saying its only well defined for R^3.
Can anyone else help me out on this?
C'mon anyone?
In [tex]\mathbb{R}^3[/tex], the cross product of two basis vectors [tex]e_1\times e_2[/tex] is orthogonal to both [tex]e_1[/tex] and [tex]e_2[/tex]. Therefore it must be parallel to [tex]e_3[/tex]. If the basis is orthonormal, then the only possibility is that [tex]e_1\times e_2 = \pm e_3[/tex]. One of these signs (up to the choice of basis) is called right-handed and the other left-handed.
In [tex]\mathbb{R}^{n\neq 3}[/tex], there is no (associative) cross product, so the definition of right and left-handed makes no sense. There's no special way of taking two basis vectors and outputting a 3rd. However, the number
[tex]\sigma(e) = \text{sgn}\left( \sum_{i_1\cdots i_n} \epsilon_{i_1\cdots i_n} (e_1)_{i_1} \cdots (e_n)_{i_n}\right) = \pm 1.[/tex]
defines an equivalence class that corresponds to the orientation of an ordered basis. If we know that the basis is orthonormal, we don't need to introduce the sign function and we simply have
[tex]\sigma(e) = \\sum_{i_1\cdots i_n} \epsilon_{i_1\cdots i_n} (e_1)_{i_1} \cdots (e_n)_{i_n}= \pm 1.[/tex]
We would call a basis with [tex]\sigma(e)=1[/tex] positively-oriented, not right-handed.
If [tex]e'[/tex] is a basis obtained by a linear transformation of [tex]e[/tex], [tex]e' = T(e)[/tex] then
[tex]\sigma(e') = \text{sgn}(\det T) \sigma(e).[/tex]
When [tex]n=3[/tex], the orientation coincides with the equivalence classes of right or left-handed.
The determinant is something you can compute for a square matrix / endomorphism. If you have a frame (a1,a2,...,an), how are you going to compute "its determinant"? This only makes sense if you have already chosen some special basis in which you express this frame; then you compute the determinant of the change-of-basis matrix.
Such a choice is precisely an orientation. In R^n you have a standard choice, namely the standard basis (e1,...,en), where e_i has 1 in the i-th slot and else zero. In an abstract vector space, there is no preferred basis. Then, given two frames (a1,a2,...,an) and (b1,b2,...,bn), we say that they 'have the same orientation' if the determinant of the linear map expressing one in the other (the 'change of basis' isomorphism) has positive determinant. This is an equivalence relation with exactly TWO classes. Choosing one such class is choosing an orientation.
  • · Replies 32 ·
