Transition of Mechanical Waves (Solids to Gases and vice versa)
The discussion revolves around the transition of mechanical waves between solids and gases, particularly in the context of sound production by musical instruments like acoustic guitars. Participants explore the complexities of modeling sound waves generated by vibrating strings and their interaction with the surrounding air, touching on aspects of acoustics, material properties, and computational modeling.
  • One participant expresses a desire to model the sounds produced by musical instruments accurately, noting the challenges in finding relevant information on the coupling between solid vibrations and sound waves in gases.
  • Another participant mentions the difficulty of accurately modeling acoustics involving reflections and suggests that scale models are often used instead of computational methods due to the complexity involved.
  • A later reply questions the specific focus of the initial inquiry, asking whether it pertains to the transduction process or the influence of materials on sound quality.
  • One participant clarifies that the vibrating string primarily excites the guitar body, which then vibrates and causes the air to vibrate, rather than the string directly exciting the air.
  • There is a discussion about the challenges of modeling the mechanical behavior of different materials, such as wood versus metal, and the need to consider the infinite extension of air in sound modeling.
  • Another participant suggests a practical approach to modeling involves measuring the guitar body's response through experimental methods, such as tapping the bridge and analyzing the resulting sound.
  • For further research, one participant recommends using the term "fluid-solid interaction" as a search term to find relevant information.
Participants express varying levels of understanding and focus on different aspects of the topic, indicating that multiple competing views remain. There is no consensus on the best approach to modeling the transition of mechanical waves between solids and gases.
The discussion highlights limitations in modeling techniques, including the complexity of material behavior and the need for comprehensive boundary conditions in simulations. There are also unresolved questions regarding the influence of different factors on sound quality and wave propagation.
elandres
As a hobby, I have been researching the different aspects of modeling the sounds produced by musical instruments. Particularly, I want to create as accurate a model as possible, and not something very simple (to which many may ask "why?" if complexity will reduce the likeliness of real time implementation, in which case a sampled recording might be preferable anyways -- again its a hobby).
That said, in my review of mechanical and sound waves, I've not found the link between waves in solids (vibrations) and the resulting sound waves propagated by them. Searching online has been difficult, as I am not sure what to search for; I've tried "coupling between solids and gases," "transition of sound between mediums," etc. My instinct tells me that my answer lies in somewhere in between the disciplines of rigid body and fluid mechanics, neither of which I am that strong in.
As a particular example, an acoustic guitar involves a plucked string that produces an initial sound, which is then resonated by an enclosed volume. The string vibration can be modeled as a transverse wave. Yet somehow it excites the air around it to produce the longitudinal sound waves, which are directed in all directions outward and perpendicular to the length of the string (something tells me that this is only partly true as the distortion of the string is assumed to be in one direction). A little more than half of the waves would propagate away from the guitar, without the resonating effects. Another portion would reflect off the guitar itself and then away from the guitar. And the remaining waves will travel into resonating cavity of the guitar, and then propagate outwards. In summation the resulting sound, would be the combination of those waves.
Acoustics involving reflections are notorously hard to model accurately, and can take stupendous amounts of computer time. To the point where they often still use scale models isntead of computers.
The sound from a guitar should be very different when heard from different directions. There might even be different interferences between waves reflected/generated at different parts of the instrument.
You can find resonant frequencies in cavities fairly easily tho. But it's beyond me how you'd work out their amplitudes and phases to know how they'd interfere with the sound generated by the strings.
Here's something from a magazine article:
"A piezoacoustic device model needs three different physics: piezoelectric stress-strain, an electric field, and pressure acoustics in a fluid. Only a multiphysics-capable simulation can define a computer model that couples the involved phenomena. ...
The boundary condition for the acoustics sets the pressure equal to the normal acceleration of the solid domain at the air and crystal interface. This drives the pressure in the air domain. On the other hand, the crystal domain is subjected to the acoustic pressure changes in the air domain."
I am unclear about your actual question.
Are you asking about the transduction process, the influence of materials on the produced sound quality, or...?
The string does not excite the air directly, to any significant extent.
The vibrating string creates a force on the guitar bridge that makes the body of the guitar vibrate. The vibration of the guitar body in the direction perpendicular to its surface is what makes the air vibrate.
The air inside the guitar also vibrates, and is coupled to the air outside by the sound-hole on the front of the guitar.
Modeliing the physics of this directly is difficult. One reason is because the mechanical behaviour of wood is much more complicated than metal. Another reason is that you have to model the air outside the guitar extending to infinity in all directions, otherwise you are not modelling the sound of the guitar itself, but the guitar played in a particular space.
A more practical approach that is part experimental and part computational is to measure the response of the guitar body. You can do that (in principle) by removing the guitar strings, and tapping the bridge with something, recording the sound produced, and analysing the recording to find the resonant frequences the amount of damping (i.e. how fast each frequency decays, after a short "tap"). You can then model the vibration of the string on its own (which is easy) and create the guitar sound by adding up the effect of each "tap" that the string applies to the guitar body.
To get "good" results with a guitar, you also need to model the effect of the player's fingers pressing the strings against the frets, and/or bending the strings to change the pitch, which is another large complication. There are some pretty good models of pianos that have been created this way, for example http://www.pianoteq.com
For Google buzzwords, try "fluid-solid interaction".
  • · Replies 19 ·
  • · Replies 25 ·
