How Is Work Calculated When Lifting an Object Vertically?
The discussion revolves around the calculation of work done when lifting an object vertically, specifically a ball, and the underlying principles of force and displacement in this context.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between force, displacement, and work, questioning how to apply the equations W=Fd and F=ma in this scenario. Some participants discuss the implications of lifting at constant velocity and the distinction between net force and the force exerted by the hand.
The conversation includes various interpretations of work and energy, with participants providing insights into the conditions under which work is done. There is an ongoing examination of the definitions and applications of work in different contexts, particularly regarding kinetic and potential energy.
Participants note the importance of distinguishing between different forces acting on the object, such as gravitational force and the force exerted by the hand, as well as the relevance of displacement in calculating work.
femmefatale8
Hello,
I have a question that should be pretty simple, but I can struggling to understand:
What determines the amount of work done in lifting a ball from one to two metres above the ground?
I know that W=Fd and F=ma , so I would assume that the work done would equal m*a*d.
Something tells me that the answer is not that simple... any help would be appreciated!
F=ma only holds for F the NET force. In this case, there are 2 forces, your hand, and gravity. The net force is zero because you should assume that you are lifting the ball at a constant velocity. So F=ma=0 so a=0.
On the other hand, the force in W=Fd can refer to which ever force individually. In this sense, the F in W=Fd is not really the same as the F in F=ma. In this case, you want F to be the force that your hand exerts on the ball, because you want to know the work done by you on the ball.
Work represents a vector dot product between F(force) and d(distance) so effectively you can say that work is only done when there is a distance changed between the origin of the position and the final position.
For example if I lift a book 1 meter off the ground and exert 10 Newtons to do so then I have done 10 J of work, the change in energy, in this case potential energy.
However, if I were to push the book 1 meter across the ground and exert 10 Newtons to do so then I have not done any work because I have not changed the net energy in the system, thus no change in energy, so no work is done.
The second example is not right because in that case the book would acquire kinetic energy. The work you do is still 10J.
Assuming it took me one second to move the book across the floor.
Er, it doesn't matter how long it took you to move the book across the floor...W=Fd and as long as d and F are non-zero and not perpendicular to each other then you do some work.
However you said that "the book would acquire kinetic energy" so by using:
KE = .5m(v^2)
Then without velocity the book wouldn't be able to acquire any kinetic energy.
Thank you, Matterwave. So, just to clear it up, the answer would simply be:
The amount of work done is determined only by the amount of force my hand exerts? Would displacement be irrelevant on on the final answer, seeing how it is 1?
By putting a force on the book, you necessarily give it kinetic energy (moving it across a smooth floor). If you want to say that friction has dissipated the kinetic energy, then you do some positive work, and friction does some negative work and the NET work comes out to be 0...but you are still doing work in that case.
Since you want to find the amount of work done by your hands, then it is only dependent on the force you exert, and the distance. In this question d=1m so when you multiply, you get X Newtons*1m = X joules. The displacement, even though it is 1 meter, is relevant! It gives you the unit conversion correctly!
9K
