Creating a Dynamo System: What Components Are Needed?
The discussion revolves around the components and feasibility of creating a small dynamo system intended to produce heat rather than light. Participants explore the necessary components and the potential for energy storage, specifically in the context of heating fluids to a moderate temperature.
  • Exploratory, Technical explanation, Debate/contested
  • One participant seeks clarification on the components needed for a small dynamo system that produces heat.
  • Another participant describes a basic dynamo setup involving magnets and wire, noting the need for a mechanism to rotate the magnets.
  • There is a suggestion that storing energy could complicate the design, with uncertainty expressed about the ability of a small dynamo to generate sufficient heat.
  • A participant proposes using the dynamo to charge a battery, which would then power a Nichrome resistance wire as a heating element.
  • Concerns are raised about the energy storage capacity of a small homemade dynamo and its ability to heat fluids to the desired temperature.
  • Further clarification is provided regarding the heating requirement, indicating that the goal is to heat fluids to around 37 degrees Celsius, which may influence the feasibility of using a small dynamo.
Participants express uncertainty about the effectiveness of a small dynamo for heating applications, with differing views on the feasibility of energy storage and the required energy output.
The discussion does not resolve the assumptions regarding the energy requirements for heating or the specific design constraints of the dynamo system.
ramtough34
Just need a bit of clarification, I am attempting to make a dynamo system but not totally sure where to start.
What components would be required? It needs to be pretty small, similar size to that used in a wind-up torch, and it will be required to produce heat rather than light.
Any help or advice would be greatly appreciated.
A basic dynamo consists of magnets and wire with a mechanism to rotate the magnets inside the coil of wire.
If you want to store the energy then that's a different issue.
I'm not sure you'd get much in the way of heat though.
thanks...there would be the possibility to store the energy. I was thinking of maybe using the dynamo to charge a battery and then using the battery to heat up the heating element.
Do you think this would be possible? I will be using Nichrome Resistance wire for the heating element, and the intention is to send the current from the dynamo to heat it up.
Well you'd need to store a fair amount of energy to achieve this. Not sure if a small home made dynamo will do the job.
Basically, it needs to heat up fluids to around 37 degrees...so it doesn't need to heat the wire up to be red hot or anything. Would you still think this wasn't possible with a small dynamo?
  • · Replies 17 ·
  • · Replies 42 ·
  • · Replies 18 ·
17K
