Can the Casimir effect be harnessed for free energy and anti-gravity?
The discussion revolves around the potential of the Casimir effect to be harnessed for free energy and anti-gravity applications. Participants explore theoretical scenarios involving the interaction of plates influenced by the Casimir effect, examining the implications of force, energy, and heat generation in this context.
  • One participant calculates that two plates, each with a surface area of 1 square meter and spaced 1 micron apart, would experience an attractive force of 0.13 grams due to the Casimir effect, suggesting this could lead to a form of free energy.
  • Another participant argues that the Casimir effect does not provide free energy, as any potential energy gained would need to be returned when the plates are separated, likening it to magnetic potential.
  • A participant questions the notion of "anti-gravity," agreeing that a force acting against gravity does not constitute true anti-gravity, and challenges the reasoning behind such claims.
  • Discussion includes the potential heat generated in the spacer, with one participant noting that heat would dissipate quickly, leading to increased energy costs when separating the plates.
  • Another participant suggests that the compression of the spacer under the Casimir force could lead to further heating, raising questions about the energy dynamics involved, though they express uncertainty about the calculations needed to quantify this energy release.
  • A correction is made regarding the measurement unit for force, with a participant noting that grams are not a standard unit of force.
Participants express disagreement on the feasibility of harnessing the Casimir effect for free energy and the definition of anti-gravity. There is no consensus on the potential energy dynamics or the implications of heat generation in the spacer.
Participants acknowledge limitations in their understanding and calculations, with some expressing uncertainty about the energy release from the heating of the spacer and the implications of entropy in the system.
GENIERE
Somewhere on the web, it was calculated that the attractive force between two plates each having a surface area of 1 square meter and spaced 1 micron apart would, due to the Casmir effect, be attracted to one another with 0.13 grams of force.
Assume machining such plates with the necessary precision were possible, further assume a spacer in the center held these impossibly rigid plates precisely 1 micron apart. The central spacer would be under compression and would be heated. This increase in temperature would be a net gain in energy. Free energy?
Assume one of the plates weighed 0.13 grams. Position the other plate and central spacer so as to be horizontal and anchored to the Earths surface. Under this plate, slowly bring the 0.13-gram plate up until it contacts the 1-micron spacer. At this point the force of the Casmir effect is equal to that of the Earth’s gravity and the plate will be suspended. Anti Gravity?
This effect works EXACTLY like magnetism. There is no free energy in magnetic potential, nor is there free energy in the Casimir effect because when you pull the plates apart, you have to give back all the potential energy you had to begin with.
And anti-gravity? C'mon. Reasoning like this is how crackpots are made. Don't fall into the trap. By that reasoning, any force that acts opposite to gravity is "anti-gravity" (and I guess by that would be the literal definition). Is a magnet anti-gravity? A rocket? Well, I'll leave it up to you, but if the answer is yes, then there is nothing special about any anti-gravity device. Taken the way scientists would, an anti-gravity device would be something that neutralizes the force of gravity, not merely acts opposite to it. Casimir (and magnetism) is an additional force added to the system, not a neutralization of another force.
Yeah Russ, I’d have to agree that force acting in opposition to gravity would not be “anti-Gravity”. What’s your feeling as to heat generated in the spacer?
Regards
If you release the pressure right away, the heat goes away. But since heat doesn't want to stay in on place, it will dissipate on its own if you don't do something with it right away. Thats entropy and that makes it take MORE energy to pull the plates apart than you got by letting them come together.
FYI force is not measured in grams :D
Should have used the unit “gram force” = .0098 Newton.
I’d like to explore the spacer heating a little more. The force on the spacer would tend to compress it however microscopically. The Casimir force increases by the forth power as the separation between the plate’s decreases. The spacer would undergo further compression and heating at an increasing rate. I see this crunch continuing until the spacer melds with the plates. My 2 physics courses were taken about 40 years ago as part of an engineering curriculum and not used since. Without re-educating myself I can’t do the calculations to determine the energy release. I would think it to be considerable, but whether more energy out then in probably not, but perhaps a use might be made of it.
Regards
  • · Replies 46 ·
  • · Replies 16 ·
  • · Replies 17 ·
