Divergent nozzle problem (find velocity)
The discussion focuses on calculating the change in velocity across an ideal divergent nozzle, given an inlet enthalpy of 1,204 Btu/lbm and an exit enthalpy of 1,203.91 Btu/lbm. The calculation yields a delta v of 67.15 ft/sec based on the formula delta v^2 = (0.09 Btu/lb) * (2) * (32.2 lbm*ft/lbf sec^2) * (778 ft lbf/Btu). Additionally, participants discuss the conversion of units to SI, highlighting the importance of using the correct formulas and tools for accurate results.
  • Understanding of thermodynamics, specifically enthalpy changes
  • Familiarity with fluid dynamics and nozzle design
  • Proficiency in unit conversion between imperial and SI units
  • Knowledge of relevant equations, such as Bernoulli's equation
  • Research the application of Bernoulli's equation in nozzle flow analysis
  • Learn about the principles of enthalpy and its role in fluid mechanics
  • Explore advanced unit conversion techniques using online calculators
  • Investigate the characteristics of ideal vs. real nozzles in fluid systems
Engineers, physicists, and students studying fluid dynamics or thermodynamics, particularly those involved in nozzle design and performance analysis.
eulerpi
Determine change in velocity across ideal divergent nozzle with inlet enthalpy of 1,204 Btu/lbm and exit enthalpy of 1,203.91 Btu/lbm
I know that delta v^2=(.09btu/lb)*(2)*(32.2lbm*ft/lbf sec^2)(778ftlbf/btu)
so: deltav^2=4509.29ft^2/sec^2
taking the sqrt deltav=67.15ft/sec
My problem is this: I need to convert the above problem to SI units
So far: (.21kj/kg)*(2)*(9.81m/sec^2)=4.1202
Any help would be appreciated!
Ken
Well, for starters, you want
h1-h2 = .5*(v2^2 - v1^2)
http://members.aol.com/ricnakk/th_nozz.html
Unfortunately for you, (v2^2-v1^2) is not equal to (v2-v1)^2. So I don't see how you can work the problem without more information, enough to determine v1.
As far as converting units, I like google calculator, for example
http://www.google.com/search?hl=en&lr=&q=btu+%2F+pound&btnG=Search
http://www.google.com/search?hl=en&q=btu+in+joules&btnG=Google+Search
(you can click on 'more about calculator to get some more help).
The documentation isn't the best, but Google thinks of a pound as a mass, and a pound force as a force.
The default output of the calculator is the value of the input in SI units, BTW.
