Urgent help need on easy significant number question
  • Thread starter Thread starter mad
    Urgent
The discussion revolves around a problem related to significant figures in the context of a colorimeter experiment. The original poster is trying to determine how many significant figures to retain in their calculations involving optical density and concentration.
  • Participants explore the significance of the constant L and its implications for significant figures. Questions arise about whether L is considered a constant and how to handle significant figures based on the measurements provided.
Some participants have offered guidance on interpreting the significance of L and its impact on the final answer's significant figures. There is a recognition that D is the limiting measurement, and multiple interpretations of how to approach the significant figures are being discussed.
There is uncertainty regarding whether L was provided as an exact number or measured, which affects the significant figures. The original poster expresses confusion about retaining significant figures in light of the measurements involved.
mad
Hello guys. I have a little problem here.. we are doing a colorimeter (sorry in advance for the english errors. I don't know if it is called like that in english I am translating from french.) experience and I have to use this formula
D = e* L * C
e= D/ LC
where L is a constant 1cm.
L= 1 cm
D= 0,783 (taken from colorimeter)
C= 0,4841 (concentration I have calculated)
Now I know I'm supposed to keep the same amount of significant numbers than the one that has the less but I know I can't keep only 1 (because of the 1cm which is only 1 number.)
So do I keep my answer with 3 or 4 ? Is D (optical density) considered a constant?
Thanks a lot
What does the value of L represent? Was it given to you in the experiment outline, or did you measure it?
Often if it's given to you in the experiment, they'll list the correct number of significant digits they'll want, such as 1.00cm. If you had to measure it yourself, my suggestion would be to measure it as accurately as you can to a few decimal places (ie: 1cm and 0mm = 1.0cm). If you do have to measure it yourself though, I'd suggest asking your teacher how many significant figures they want from that measurement.
From your statement "L is a constant 1cm.", I would guess that L is "given" as an exact number. If that is the case, D is the "limiting" measurement. Since it has 3 significant figures, your result should have 3 significant figures.
Thats what I did. Thank you for your help.
  • · Replies 25 ·
  • · Replies 19 ·
