Register to reply
Current Between Long Straight Conducting Wires
by futurepocket
Tags: current, fields, force, magnetic, wires
Share this thread:
futurepocket
#1
Mar5-11, 03:53 PM
P: 10
Two identical long straight conducting wires with a mass per unit length of 25.0 g/m are resting parallel to each other on a table. The wires are separated by 2.5 mm and are carrying currents in opposite directions.
a) If the coefficient of static friction between the wires and the table is 0.035, what minimum current is necessary to make the wires start to move?
b) Do the wires move closer together or farther apart?
2. Relevant equations
F(b) = ILB
B = muo(0)I/2pi(r)
F(sf) = muo(s)F(n)
3. The attempt at a solution
Okay, so I realized that for the wires to start moving, the force due to the magnetic field has to equal (match) the force of friction, so I equate the two:
F(b) = ILB = muo(s)F(n)
Then, I realize that F(n) = mg
ILB = muo(s)mg
If you divide out the length, you can get the mass per unit length, so you get:
IB = 0.025muo(s)g
I = 0.025muo(s)g / B
I know the equation to solve for the magnetic field, but at which point am I solving it for so I know the radius to use? You can't really use the center between the wires because the currents are in opposite direction and they are equal, so in the center of the two wires, the magnetic field is 0. Any ideas?
Thank you!
Phys.Org News Partner Science news on Phys.org
Hoverbike drone project for air transport takes off
Earlier Stone Age artifacts found in Northern Cape of South Africa
Study reveals new characteristics of complex oxide surfaces
Register to reply
Related Discussions
Magnetic Fields of Long Straight Wires Introductory Physics Homework 10
Magnetic field of long parallel straight wires Introductory Physics Homework 3
Magnetic field between two long, straight wires Introductory Physics Homework 2
Two very long straight conducting wires problem Introductory Physics Homework 2
Magnetic field between two long straight wires Introductory Physics Homework 6
