New Reply
LED monitor not working well
Share Thread Thread Tools
Mar6-11, 11:21 PM   #1
Recognitions:
Gold Membership Gold Member
I bought a LED monitor less than a month ago. Until yesterday I never had any kind of problem, all worked perfectly well.
Today while I was away from keyboard but still close to the screen, I saw that the screen suddenly turned all black with large (maybe 100 pixels, I don't really know) white/very clear pink vertical stripes. I couldn't see my desktop at all nor anything familiar but these vertical stripes.
I turned off all my computer, checked out 3 times the plugs. Turned on and I couldn't even see anything but these stripes.
After an hour of desperate tries, it worked back. However I still have a major stripe (clearer than the normal background, about maybe 100 pixels large) with a red vertical 1 pixel stripe constantly flashing.
I've tried to plug my CRT monitor and I have no problem at all, so it's not my graphic card but my LED monitor.
I took so much care of it that I can't think about anything bad that could happen to it, not even electricity problems since I've plugged it through a stabilizer just like my whole computer. The ambiant is not too dry, not too wet. The monitor has not a single scratch nor anything different from a new one.
I've searched a lot on google and never read anything like that.
Do you have any idea of what it might be?
The model is a LG flatron E1940. Fortunately I have the warranty so I'll head there as soon as I can (probably wednesday afternoon).
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Mar7-11, 12:07 AM   #2
Quote by fluidistic View Post
Are you using analog (VGA) on the LCD monitor or DVI? It could be the DVI output on the card that is messed up. If neither VGA nor DVI work with the LCD monitor, then something is likely blown inside the monitor. Maybe it's just some of the electronics, not necessarily the screen. These things can happen. There may be a manufacturing defect that did not manifest itself until now. That's why they give you a warranty.
Try another PC if you can to make sure it's the monitor that is broken. If you're sure, then return it for warranty repair/replacement. Even if it starts working again, I would ask for a replacement. It could happen again, usually the day after your warranty runs out.
Mar7-11, 01:19 AM   #3
Just a random chance: try changing the cable that you're using. I've had lots of problems with monitors where it turned out just to be the cable.
Mar7-11, 10:16 AM   #4
Recognitions:
If the VGA is the left plug and DVI is the right plug on this picture: http://www.google.com.ar/imgres?imgu...0&tx=134&ty=80, then I'm using VGA and I don't have any DVI plug.
Ok, before heading to the store where I bought it I'll ask them if I can try out another cable (and give mine). If this doesn't work I'll go with my monitor.
I won't be able to go there before Thursday. As soon as I know what the problem was, I'll tell you (I myself find it interesting).
Thanks a lot for your tips.
Mar7-11, 10:37 AM   #5
Left is VGA, right is DVI-A (analog). Normally for a digital monitor DVI-D (digital) is used. Same plug as DVI-A, but different pinout.
But anyway, if you used the VGA out for both the CRT and LCD monitors, it clears the card. Something is wrong with the monitor or cable.
Mar7-11, 11:58 AM   #6
You should try and get a DVI-D cable for a monitor of that caliber, ideally, you would not use VGA for anything other than a CRT as it can compromise quality and, in some cases, performance.
That is, of course, as long as your videocard has a DVI-D out.
Mar10-11, 02:24 AM   #7
Recognitions:
LED monitors process video signals different than CRT's. Have you tried another LED monitor? If the problem persists the the signal [i.e., GPU] is to blame. You can also try another GPU, if the problem persists the monitor is to blame. My money is on the monitor. Fortunately, LG has a good reputation for covering warranty claims.
Mar10-11, 09:04 AM   #8
Recognitions:
I don't have any other LCD screen so no, I didn't try any other.
What is really strange is that the brighter than background large vertical stripe starts right in the middle on my screen.
During the time I had this screen (maybe 22 days), I used a lot (about 6 times a day I'd say) the options to change the brightness of the screen. There are the options "movie", "internet" and "normal". When you try on of these, half of the screen turns to the selected brightness and the other half stays as it was before you chose the option, so that you can compare the difference of brightness. Until of course you leave the option menu and all the screen turn what you selected. Well, the left part of the stripe starts right where the limit of the difference of brightnesses is.
I'm heading to the store I bought it in about one hour now. I'll let you know what happens.
Mar23-11, 08:57 PM   #9
Recognitions:
I just got their answer: the monitor couldn't be repaired and the fail was due to the panel (apparently what I had guessed). They gave me a new one. Instead of being really satisfied, I'm still afraid the problem might rise one more time.
Mar23-11, 10:10 PM   #10
Interesting. The problem could happen again, but I don't think that is statistically likely, since a panel problem from a monitor that new would arise from a manufacturer's error.
Mar23-11, 11:01 PM   #11
Recognitions:
Quote by KrisOhn View Post
Yes and that's what I'm afraid of.
New Reply
Thread Tools
Similar Threads for: LED monitor not working well
Thread Forum Replies
Battery Monitor Electrical Engineering 1
Old PC and CRT monitor General Discussion 7
Has anybody here ever taken apart an LCD monitor? General Discussion 1
Monitor Computing & Technology 7
