Can electromagnetic fields produce space-time curvature?
The discussion explores whether electromagnetic fields can produce space-time curvature, examining theoretical implications and experimental evidence related to energy and gravity. Participants engage with concepts from general relativity and electromagnetism, considering both static and dynamic scenarios.
  • Some participants suggest that energy in general leads to space-time curvature, questioning if electromagnetism specifically contributes to this effect.
  • One participant notes that electrostatic energy in materials like gold and aluminum is small compared to their total mass, implying that electromagnetism may not generate significant curvature.
  • Another participant argues that electromagnetic fields do generate space-time curvature, citing that fluctuations in electric and magnetic fields (like those from photons) carry energy and momentum, which should affect curvature.
  • It is proposed that a stationary point charge does not create curvature because its electric field lacks independent energy, while dynamic fields do contribute to curvature.
  • One participant emphasizes that nuclear and electronic binding energies should be treated similarly in terms of their contribution to mass and gravitational effects, suggesting that total energy is what matters in gravitational interactions.
  • Another viewpoint states that a high amount of energy is required to produce noticeable curvature, referencing the mass-energy equivalence principle (E=mc²).
  • Some participants express uncertainty about the implications of their arguments and the need for further exploration of the equivalence principle in relation to different energy distributions.
Participants do not reach consensus on whether electromagnetic fields produce space-time curvature. Multiple competing views are presented, with some arguing for a positive correlation and others suggesting minimal or no effect.
Participants reference various theoretical frameworks and experimental results, including Eötvös experiments, but do not resolve the implications of these references for the discussion at hand. The treatment of energy types and their contributions to mass and curvature remains a point of contention.
blue_sky
Energy---> space time curvature
In general energy---> space-time curvature
Any sperimental evidence that electromagnetism--->space-time curvature?
blue
blue
As I mentioned before, gold and aluminum have different amounts of electrostatic energy. I think the figures were .4% and .1% of the total mass of the atoms were due
But we know from Eotovos experiments that both are affected by gravity in the same way.
Thanks... but this looks like that electromagnetism doesn't generate space time curvature. I got it correctly?
blue
Electromagnetism does generate spacetime curvature, i think. Here's my reasoning:
Light propagates a flucttuation in both the electric and magnetic fields. These fluctuations can be represented as the bosons called photons (just go with me here), and photons have momentum and energy, and do cause space time curvature.
The point I'm making is that the electromagnetic field carries energy, and so should cause spacetime curvature, but only if it carries its own energy as in the case of light. If for example, we just have a stationary point charge, there is no curvature, because the electric field possesses no energy of its own independsnt of a charge placed in it.
note: I'm only speculating here.
blue
I'm not sure why you think that.
It's been demonstrated very - vigorously - that nuclear binding energies affect the mass of atoms. A coherent treatment of energy requires that electronic binding energies be treated in the same way as nuclear binding energies, that they affect the mass of atoms.
The way the treatment works is that a bound system has a lower mass than an unbound system.
It can be seen from the figures quoted that the total electronic binding energies are not a negligible part of the mass of atoms (.1% and .4% for Al and Gold).
[edit]
Note that in normal chemical reactions, only the outer electrons are involved. The energies here are low, the effect on mass is small enough to be ignored. But when you add together ALL of the electronic energy, esp. for heavy elements, it's a lot larger, because the inner electrons are very strongly bound, and the contribution to total energy is no longer negligible.
[end edit]
There's some more data on the magnitude of electronic binding energies at
http://xray.uu.se/hypertext/EBindEnergies.html
but I haven't personally added up these numbers and computed E/c^2, I've been relying on my text (MTW's Gravitation) to be accurate about the total percentage of energy that's binding energy in these elments.
Comparing elements with a different amount of differing binding energies (i.e. different amounts of electronic binding energy, differing amounts of nuclear binding energy) in an Eotovos type balance should determine if elements with different sorts of energy distributions act differently with respect to gravity, or whether only the total energy matters.
This is actually a test of the equivalence principle.
To date, it's been found that only the total energy counts, it doesn't matter how much of it is nuclear binding energy, chemical binding energy, etc.
well, according to E=mc^2, energy is proportional to mass. so i guess it could bend spacetime but you would need a very high amount of energy because m = E/c^2. if this has been posted, sorry, i didnt read any of the other posts.
Even in classical electrodyamics and EM field can have energy, momentum and stress. There is no need to invoke photons to arrive at this conclusion. From this it follows that the stress-energy-momentum tensor, Tuv, is non-zero and at evets for which it is non-zero there is a non-vanishing spacetime curvature.
The point I'm making is that the electromagnetic field carries energy, ..
...and therefore mass..
...and so should cause spacetime curvature, but only if it carries its own energy as in the case of light. If for example, we just have a stationary point charge, there is no curvature, because the electric field possesses no energy of its own independsnt of a charge placed in it.
There is energy in/associated with all electric and magnetic field fields, even when they are static fields. If one then changes their frame of referece to one moving with respect to the charges rest frame then in that frame the momentum density of the fields will not vanish.
Pete
  • · Replies 58 ·
  • · Replies 32 ·
  • · Replies 26 ·
  • · Replies 62 ·
