New Reply
How to find vector magnetic potential given magnetic field?
Share Thread Thread Tools
Mar9-11, 12:05 PM   #1
If we are given B, how can we find A? I can fine the magnitude of A by:
[tex] \int_{s'} \vec B \cdot d\vec{s'} = \int_{s'} (\nabla X \vec A) \cdot d\vec{s'} = \int_{C} \vec A \cdot d\vec{l}[/tex]
So given B and the surface area, you can get the magnitude of A.
But how do you get the direction information? All I know is A is orthogonal to B and [itex]\vec B = \nabla X \vec A [/itex]. But still I cannot find a formula to nail down the direction.
Anyone can help?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Mar9-11, 02:26 PM   #2
Recognitions:
It's a bit like long division. There is no general result. For a specific B, you try to find a vector A whose curl is that B. If you can write B in a coordinate system, then you can write partial differential equations whose solution give A.
You can also use divB=-del^2 A and solve that equation for A.
Mar9-11, 09:59 PM   #3
Quote by yungman View Post
Anyone can help?
How is it true that A is orthogonal to B?
Also, I don't see how:
gets you the magnitude of A.
Mar9-11, 10:00 PM   #4
Quote by clem View Post
divB=0 is one of the Maxwell equations.
Mar9-11, 11:23 PM   #5
Quote by RedX View Post
The curl of a vector is always orthogonal to the original vector. eg.
[tex]\hat x \;X\; \hat y = \hat z [/tex]
[tex] \Phi = \int_{s'} \vec B \cdot d\vec{s'} \;\Rightarrow \;\int_{C} \vec A \cdot d\vec{l}= \Phi[/tex]
So If you are given the B and given the surface that the flux cut through. You get the A within that surface.
Mar9-11, 11:49 PM   #6
The vector field (y,0,1) has a curl in the z-direction, but is not perpendicular to the z-direction.
As for your second equation, you can get the line integral of A around the perimeter of the surface, but I don't think you can get A at a particular point on the perimeter, or at the center point of the surface.
addendum: here's a way to visualize why you can't get A at a particular point on the perimeter. This is a tri-force taken from a popular classic video game:
http://www.google.com/imgres?imgurl=...ed=0CB0Q9QEwAA
You know the line integral of the middle triangle. But you want the field on the left side of that middle triangle. So how do you isolate just that part? Well you know the line integral of the leftmost triangle, and the rightmost part of the leftmost triangle is what you're looking for. So by considering the leftmost triangle, you do get an extra equation involving the left side of the middle triangle, but unfortunately this equation causes you to have two more sides (the remaining sides of the leftmost triangle), so in general you don't have enough information to get A at all. I hope this is right - someone correct me if I'm wrong!
Mar10-11, 06:19 AM   #7
Recognitions:
Homework Helper Homework Help
I think he meant curl B.
Mar10-11, 11:40 AM   #8
The simplest way to do it, for a general B, is via a PDE problem:
[tex]\nabla^2 \vec A =-\mu_0\vec J[/tex]
whilst remembering that
[tex]\nabla\times \vec B =\mu_0\vec J[/tex]
This, togther with suitable boundary conditions, (eg. specifing B on the boundary) should give you the result you are looking for. Please note, that an analytical solution may not be obtainable.
The "Amperes Law for A" method;
[tex]\int_S \vec B\cdot d\vec a = \oint_{\partial S} \vec A\cdot d\vec l[/tex]
That you suggested in your OP works only if you have some suitable symmetry in the problem (ie A and dl are parallel at all points along the integration curve). The only case I can think of off the top of my head is the magnetic potential inside an infinitely long solenoid
Mar10-11, 05:25 PM   #9
My bad, I keep thinking about A X B is always orthogonal to A or B.
I am still reading the materials in the book.
Mar10-11, 05:27 PM   #10
Quote by Troels View Post
So
[tex]\int_S \vec B\cdot d\vec a = \oint_{C} \vec A\cdot d\vec l[/tex]
can only be true with certain symetry like a long wire carrying current or a long solenoid?
Yes this is from a problem of a long solenoid.
Mar10-11, 05:59 PM   #11
I read Griffiths page 234 in Magnetic Vector Potential in STATIC condition where [itex]\nabla X \vec B = \mu_0 \vec J [/itex].
[tex] \nabla X \vec B= \nabla X \nabla X \vec A = \nabla(\nabla \cdot \vec A ) - \nabla^2 \vac A = \mu_0 \vec J [/tex]
We invoke gauge where [itex] \nabla \cdot \vec A = 0 [/tex]
[tex]\Rightarrow\; \nabla^2 \vec A =-\mu_0 \vec J [/tex]
Does this imply in all cases of static condition, A and J are in the same direction in all static case?
On the other note, for time varying condition where:
[tex] \nabla X \vec B = \mu_0 \vec J + \mu_0 \epsilon_0 \frac {\partial {\vec E}}{ \partial t}[/tex]
A and J are not in the same direction.
Am I correct?
Mar11-11, 05:43 AM   #12
Recognitions:
Del^2A need not be in the same direction as A.
Mar11-11, 11:17 AM   #13
Quote by Meir Achuz View Post
I skipped a step to show that
[tex] \nabla^2 \vec A = -\mu_0 \vec J \;\Rightarrow\; \vec A(\vec r) = \frac {\mu_0}{4\pi}\int_{v'} \frac {\vec J(\vec r)}{|\vec r|} dv' [/tex]
And
[tex] \vec A = \frac {\mu_0}{4\pi}\oint_{C'} \frac {\vec I}{|\vec r|} dl' [/tex]
That shows A is same direction of J. Is this right?
Mar11-11, 11:58 AM   #14
So
Don't get me wrong. The equation - like amperes law - is always true, but - likewise like amperes law - it is only useful in finding the magnetude of A along the integration curve - you have to dream up the direction from a symmetry argument.
To adress your other question, no. In general you cannot assume that A and J are parallel at all points, but this is where symmetry comes in. In case of a a solenoid, you have current running in the [tex]\hat \phi[/tex]-direction only and thus the PDE becomes:
[tex]\nabla^2 A_r = 0[/tex]
[tex]\nabla^2 A_\phi = J_{\phi}[/tex]
[tex]\nabla^2 A_z = 0[/tex]
A trial solution of Ar=Az=0 satisfies the first and last equation and thus, by the uniqueness theorem, are the solutions, thus A has only a phi-component, in this case.
Mar11-11, 04:15 PM   #15
Recognitions:
And
Still NO.
Mar11-11, 04:39 PM   #16
Still NO.
Can you explain? There is only one vector on the left and only one on the right. How can they not be in the same direction. In fact it is common to pull the unit vector out and put them in front of the equation.
[tex] \Rightarrow\; (\hat A)\; A \;=\; (\hat I)\;[\frac {\mu_0}{4\pi}\oint_{C'} \frac {I}{|\vec r|} dl'] [/tex]
[tex] \Rightarrow\;\hat A =\hat I [/tex]
Mar11-11, 07:00 PM   #17
Lookup Helmholtz decomposition for vector fields, which I think is what you're tiptoeing around.
http://en.wikipedia.org/wiki/Helmholtz_decomposition
It will give you the vector potential from the field, or field from the potential.
New Reply
Thread Tools
Similar Threads for: How to find vector magnetic potential given magnetic field?
Thread Forum Replies
Moving charge in a magnetic field, magnetic-magnetic interaction? General Physics 6
coils rotating in a magnetic field find maximum emf and magnetic feild strength Introductory Physics Homework 1
Magnetic Field from quantized vector potential Advanced Physics Homework 0
Find k from magnetic field and magnetic flux. Advanced Physics Homework 4
Rotating magnetic field, find potential difference. Advanced Physics Homework 0
