Kinematics, Throw-up problem
by cidilon
Tags: kinematics, throwup
cidilon
cidilon is offline
#1
Mar9-11, 03:27 PM
P: 11
Marian, who is standing on her balcony, is surprised by a pigeon and throws a flowerpot up in the air at 2.1 m/s. It takes 3.0 s for the flowerpot to smash to the ground. The flowerpot experiences acceleration due to gravity of 9.81m/s2 [down].
a) How high is Marian's balcony?
b) How fast was the flowerpot moving just before it smashed to the ground?
v1= 2.1 [up]
a= -9.81m/s2 [up]
t= 3.0 s
2. Relevant equations
Since acceleration is constant
d = v1*t + .5*a*t*t
v2[squared] = v1[squared] + 2*a*d
3. The attempt at a solution
a)
First i used d = v1*t + .5*a*t*t
d = 2.1*3.0 + .5*-9.81*3.0*3.0
d = -37.8 m [up] or -38 m [up] ---> i round it to 2 sig figs here, right?
Now here is where i get confused.
This is negative displacement because the flower pot is flying most of it's way down to the ground. Right? What i am confused about is, is this the actual displacement from the balcony to the ground? Is Marian's balcony 38 m high?
It just seems not right to me for some reason, it feels like i am missing some sort of step.
If this is the answer, then for b) i use
v2[squared] = 2.1[squared] + 2(-9.81)(-38)
v2[squared] = 749.97[square root]
v2 = 27.4 m/s or 27 m/s --->should i make it three or two figs. I think two figs, right?
If everything is correct so far, why do i have positive velocity instead of negative. Should it not be negative?
Thanks in advance and if i am totally wrong, please do correct me :)
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
tiny-tim
tiny-tim is offline
#2
Mar9-11, 03:48 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
hi cidilon! welcome to pf!
(have a square-root: √ and try using the X2 and X2 icons just above the Reply box )
Quote Quote by cidilon View Post
yes, Marian's balcony is 38 m high (plus the height of her hand when she throws)
the displacement is from the initial position
if v2 = 27, v can be negative
(and yes, 2 sig figs)
cidilon
cidilon is offline
#3
Mar9-11, 03:55 PM
P: 11
Quote Quote by tiny-tim View Post
So in this case it has to be negative right?
Did i just not get the negative because for displacement i used -38m, instead of just 38 which should be used this time around?
Thanks for the warm welcome :)
tiny-tim
tiny-tim is offline
#4
Mar9-11, 04:05 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
the question asked "how fast ", so the answer has to be positive
(how you get to the answer, ie whether you measure up or down, is up to you or down to you but you must answer the question as asked!)
cidilon
cidilon is offline
#5
Mar9-11, 04:16 PM
P: 11
Okay, so the answer is positive. Is my answer incorrect? Am i not answering the question asked? Sorry for my confusion!
tiny-tim
tiny-tim is offline
#6
Mar9-11, 04:19 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
√(27.4), to 2 sig figs, is correct
cidilon
cidilon is offline
#7
Mar9-11, 04:42 PM
P: 11
I have to square root 27.4 again? I mean i got the answer by square rooting, why do i have to do it again? I have a feeling i started overcomplicating things again...
tiny-tim
tiny-tim is offline
#8
Mar9-11, 04:51 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
ohhh! i misread that
as v2 !
cidilon
cidilon is offline
#9
Mar9-11, 05:02 PM
P: 11
Awesome, thanks! :)
cidilon
cidilon is offline
#10
Mar9-11, 06:32 PM
P: 11
Sorry to post again but i am confused about something else as well.
To get the second velocity i can also use v2 = v1 + a*t
If i do it this way i get -27 [up] instead of 27 [up] as with previous equation.
First, i am confused as to why i get different results? I understand that the question asked "how fast..." but doesn't -27 just mean that the motion is going in the opposite direction of the initial motion. So, the initial velocity was 2.1 m/s [up] and the second is 27 [down] or -27 [up] because it is going in the other direction. I am just confused that you said that when it says "how fast" it must be positive.
Also if possible, please can you explain why i keep getting 27 with first equation and -27 with second. Which equation should i used? The only reason i think that might happen is that when i use this equation...
..for displacement i put -38 instead of 38, which probably should be there instead.
Although i am not sure if i can set it as positive, if in my previous answer it was negative in relation to the balcony. So should it not remain negative here as well? Hmm..
Please look this over, i want to be confident :)
tiny-tim
tiny-tim is offline
#11
Mar10-11, 03:39 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
hi cidilon!
(just got up )
if your equation has a square, then you can have either + or -
you have to look at the reality to see which one it is!
this is english rather than maths
"how fast" is always positive
(translated into maths, the question would ask "what is the magnitude of the velocity?")
cidilon
cidilon is offline
#12
Mar10-11, 12:19 PM
P: 11
The only reason why i am concerned is that it just does not make sense that v2 is positive because it is flying [down] compared to v1 which is flying up. I understand that when i measure v2 it is accelerating down in the negative direction which makes it positive. Therefore my answer has to be positive... but my answer for v2 is it 27m/s [down]? I mean, that would make sense but as the answer was positive it can not really be [down] which is negative. If it is [up] then i am even more confused, as v1 is [up]. What do you mean by "if your equation has a square, then you can have either + or -"?
Thanks,
I am also very sorry for bugging you so much, i hope i am not getting on your nerves!
tiny-tim
tiny-tim is offline
#13
Mar10-11, 12:27 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
you had
so v2 = √(2.1[squared] + 2(-9.81)(-38))
both + and - are solutions to that equation
cidilon
cidilon is offline
#14
Mar10-11, 01:28 PM
P: 11
I finally got it, thank-you so much!!
Register to reply
Related Discussions
A quarterback can throw 60yd @ 45 degree angle. How fast can he throw? Introductory Physics Homework 4
[1D kinematics] Car problem: Solving problem with a graph Introductory Physics Homework 1
[111] Throw-up problem - Launch/freefall Introductory Physics Homework 1
Throw Up Problem Introductory Physics Homework 3
