Doppler Coefficient Values: BOL & EOL in SI & Kelvin
The Doppler coefficient values for core life are established as -1 * 10^-5 Δk/k/°F at Beginning of Life (BOL) and -1.5 * 10^-5 Δk/k/°F at End of Life (EOL). These values can be converted to SI units, specifically Kelvin, using the conversion factor between Fahrenheit and Celsius degrees. The conversion yields BOL as 1.8 * 10^-5 Δk/k/K and EOL as 2.7 * 10^-5 Δk/k/K, confirming that the values in Kelvin are equivalent to those in Celsius.
  • Understanding of Doppler coefficient terminology
  • Knowledge of temperature conversion between Fahrenheit and Celsius
  • Familiarity with SI unit measurements
  • Basic principles of thermodynamics
  • Research the implications of Doppler coefficients in nuclear reactor physics
  • Study temperature conversion methods in scientific calculations
  • Explore the significance of SI units in scientific reporting
  • Investigate the effects of temperature on material properties in engineering
Physicists, engineers, and researchers involved in nuclear science, thermodynamics, or any field requiring precise temperature measurements and conversions.
eulerpi
I know that the typical values of Doppler coefficient over core life are about -1 *10^-5 Deltak/k/°F at BOL and -1.5 * 10^-5 Deltak/k/°F at EOL.
What are the value in SI units?
Are they the same, but in Kelvin?
Thanks,
Ken
Thanks,
Ken
Ken,
Since a Celsius degree [ not degree Celsius - but Celsius degree -
the size of the interval ] is 9/5 a Fahrenheit degree - you can do the conversion.
Celsius degree = 9/5 Fahrenheit degree.
Divide by "Celsius degree":
1 = 9/5 Fahrenheit degree / Celsius degree = 1.8 F deg / C deg
Since this equals 1 - you can multiply any quantity by it without
changing the value.
If you take the BOL value of 1.0 * 10^-5 Delta k/k/F deg and multiply by
the above, and divide out the units that cancel - you get
1.8 * 10^-5 Delta k/ k / C deg = 1.8 * 10^-5 Delta k /k / Kelvin deg
the latter part is because the size of the Kelvin degree equals the size
of the Celsius degree.
Dr. Gregory Greenman
Physicist LLNL
9K
  • · Replies 64 ·
  • · Replies 56 ·
  • · Replies 20 ·
