| New Reply |
What does the probabilistic interpretation of QM claim? |
Share Thread |
| Mar17-11, 12:28 PM | #52 |
Recognitions:
What does the probabilistic interpretation of QM claim?In my thermal interpretation of quantum physics, the directly observable (and hence obviously ''real'') features of a macroscopic system are the expectation values of the most important fields Phi(x,t) at position x and time t, as they are described by statistical thermodynamics. If it were not so, thermodynamics would not provide the good macroscopic description it does. However, the expectation values have only a limited accuracy; as discovered by Heisenberg, quantum mechanics predicts its own uncertainty. This means that <Phi(x)> is objectively real only to an accuracy of order 1/sqrt(V) where V is the volume occupied by the mesoscopic cell containing x, assumed to be homogeneous and in local equilibrium. This is the standard assumption for deriving from first principles hydrodynamical equations and the like. It means that the interpretation of a field gets more fuzzy as one decreases the size of the coarse graining - until at some point the local equilibrium hypothesis is no longer valid. This defines the surface ontology of the thermal interpretation. There is also a deeper ontology concerning the reality of inferred entities - the thermal interpretation declares as real but not directly observable any expectation <A(x,t)> of operators with a space-time dependence that satisfy Poincare invariance and causal commutation relations. These are distributions that produce exact numbers when integrated over sufficiently smooth localized test functions. Approximating a multiparticle system in a semiclassical way (mean field theory or a little beyond) gives an approximate deterministic system governing the dynamics of these expectations. This system is highly chaotic at high resolution. This chaoticity seems enough to enforce the probabilistic nature of the measurement apparatus. Neither an underlying exact deterministic dynamics nor an explicit dynamical collapse needs to be postulated. |
| Mar17-11, 12:37 PM | #53 |
Sorry, but chaotic dynamics is an exact mathematical model, that's the whole point of it, you can't say it's "emergent". Sensitive dependence at infinitesimally small changes in the the dynamical parameters is part of the definition of chaotic dynamics. If you have a stochastic dynamics then you have stochastic dynamics, if you have deterministic dynamics then you have deterministic dynamics, there's no inbetween "emergent" type system.
| Mar17-11, 12:56 PM | #54 |
Recognitions:
The same system can be studied at different levels of resolution. When we model a dynamical system classically at high enough resolution, it must be modeled stochastically since the quantum uncertainties must be taken into account. But at a lower resolution, one can often neglect the stochastic part and the system becomes deterministic. If it were not so, we could not use any deterministic model at all in physics but we often do, with excellent success. This also holds when the resulting deterministic system is chaotic. Indeed, all deterministic chaotic systems studied in practice are approximate only, because of quantum mechanics. If it were not so, we could not use any chaotic model at all in physics but we often do, with excellent success. |
| Mar17-11, 01:02 PM | #55 |
| Mar17-11, 01:09 PM | #56 |
Recognitions:
| Mar17-11, 01:14 PM | #57 |
| Mar17-11, 01:19 PM | #58 |
Eugene. |
| Mar17-11, 01:19 PM | #59 |
Recognitions:
By the way, the url in your profile is spelled incorrectly. |
| Mar17-11, 01:26 PM | #60 |
Recognitions:
We never ''look at an electron experimentally'' - we only infer its presence from a measured current or ionization track. Mott shows that this track is produced by a classical spherical wave impinging on the cloud chamber from a certain direction, which will determine the direction of the track produced at the atom that happens to fire. There is nothing counterintuitive about that. The uncertainty in the charge density inside the detector is much larger than the charge of one electron. You _assume_ instead that this is caused by a single electron. And then you say that you find it because of the track. This is a simple instance of a self-fulfilling prophecy. http://en.wikipedia.org/wiki/Self-fulfilling_prophecy |
| Mar17-11, 01:28 PM | #61 |
| Mar17-11, 08:26 PM | #62 |
Eugene. |
| Mar17-11, 09:21 PM | #63 |
Recognitions:
I.e., emits definitely one and only one electron, presumably with a momentum uncertainty corresponding to a small solid angle that exactly encompasses the CCD device. |
| Mar18-11, 12:04 AM | #64 |
Recognitions:
experiment with the following assumptions: Maxwell equations" in these slides. (Or are you implicitly referring to the arguments given in Mandel & Wolf?) You go on to say: listed, one has assumed point particle structure. |
| Mar18-11, 12:05 AM | #65 |
You can say that the emitted electron flies in a random direction, so, most likely, it will not be found in our measuring device. But if we are persistent and prepare another radioactive nucleus, then another one... Eventually, we will be able to catch the electron and perfrom the experiment. If this electron passes through a crystal, then the effect of "electron diffraction" occurs, which is basically similar to the occurence of interference picture in the famous double slit experiment. There are probability peaks in certain directions of electron propagation. The preferential angles depend on the (1) initial electron's momentum, (2) type of the crystal lattice, (3) orientation of the crystal. So, it should not be difficult to arrange all components in such a way that the diffraction (or interference) picture covers the entire surface of the CCD device. Eugene. |
| Mar18-11, 12:19 AM | #66 |
Recognitions:
he uses alpha particles instead of electrons). But you have not specified a way to observe the electron on its way from nucleus to target (and I'm not sure what you meant by "catch the electron"). Instead, you're relying on random emission by nuclear decay. I don't see how this is practical except by having a sample of the radioactive material with many nuclei, and this leads to an ensemble of emitted electrons, with nonzero probability of more than 1 electron in any given time interval. |
| Mar18-11, 12:31 AM | #67 |
Eugene. EDIT: I've googled for "single electron source" and found a number of interesting references. So, I guess that preparation of one-electron states is a solved technical problem. See, for example, J.-Y. Chesnel, A. Hajaji, R. O. Barrachina, and F. Frémont, Young-Type Experiment Using a Single-Electron Source and an Independent Atomic-Size Two-Center Interferometer. Phys. Rev. Lett. 98, 100403 (2007). http://prl.aps.org/abstract/PRL/v98/i10/e100403 |
| Mar18-11, 01:45 AM | #68 |
Recognitions:
conclusion about it being a "solved technical problem" in the way you seem to mean. I think such a description is an over-claim indeed. The various setups I saw appear quite elaborate, specific to particular applications that don't correspond easily to what you wanted (imho). As usual, the devil is in the detail... The experiment consists of an incident beam of alpha particles, striking a gas of [tex]H_2[/tex] molecules. There's a particle reaction chain in which the alpha particle becomes a doubly-excited helium atom by capturing two electrons from a hydrogen molecule. The two resultant protons move apart a little, and the doubly-excited helium atom decays, re-emitting the electrons. Sometimes, one of the electrons is re-emitted back towards the 2-proton target which acts like a 2-centre scatterer. The resultant scattering pattern of such back-emitted electrons is recorded. The "result" of the experiment is thus a scattering cross section. The experiment is called "single-electron" only because the probability is extremely low that more than one electron is scattered by a given 2-proton scatterer. I.e., it's "single-electron" within the lifetime of the 2-proton scatterer. On the 2nd page, the authors clarify further that: |
| New Reply |
Similar discussions for: What does the probabilistic interpretation of QM claim?
| Is their a probabilistic to deterministic calculator web abb? | General Math | 4 | ||
| A probabilistic inequality | Set Theory, Logic, Probability, Statistics | 3 | ||
| The Probabilistic argument | Linear & Abstract Algebra | 3 | ||
| probabilistic interpretation of wave function | Advanced Physics Homework | 5 | ||
| problem with Probabilistic | Set Theory, Logic, Probability, Statistics | 0 | ||
