New Reply
Japan Earthquake: nuclear plants
Share Thread Thread Tools
Mar28-11, 08:14 AM   #1701
I just stumbled upon someone who plotted various variables over time for reactors 1,2, and 3 (pressures, water levels,...), this might be helpful to understand how things evolve in the reactors:
http://www.ic.unicamp.br/~stolfi/EXP...s/v6/Main.html
Mar28-11, 08:15 AM   #1702
Someone has plotted all the reactor data 12-27th March onto 3 graphs:
edit: lol - see above post. I would love to see data from the past 48hrs too.
Mar28-11, 08:25 AM   #1703
Quote by Bodge View Post
Duh! Does it not seem reasonable that there would be a protocol for data acquisition and data reporting after any nuclear power plant accident that would be standardized?
Mar28-11, 08:25 AM   #1704
I did specify that it was not a picture from unit 1-4 it is a picture of the 6th pictured here
http://www.stufftotweet.com/tweetthi...copy_thumb.jpg
The building has a different orientation reason why South North on the wall are not in the right place in respect of unit 1-5.
Tanaka did said that the layout of the operating floor was the same (he toke part in the design of unit 4)
(for the time being and until provided with better information I'm taking his word for it , The documents from oyster creek do not give us better information as we now know that despite what has been done in infography in the media, the Fukushima reactors do not use a Mark-1 but an "improved" Mark-1 with a different Containment vessel for ex)
Mar28-11, 08:37 AM   #1705
I wanted to mention some important details in the last french IRSN report from this morning (source: http://www.irsn.fr/FR/Actualites_pre...u_japon.aspx#1 ).
They are giving infos on the levels of water found in the basement of reactor n°2 and N°3, and the levels are much higher than what i have seen reported so far. They are talking about 1 m of water in the basement of turbine building at N°2 and 1,5m in the basement of turbine building at N°3! Until now i was staying with numbers like 15 or 30 cms of water in N°3 (when the 3 workers were injured walking in this water)...
Does it mean that this level has dramatically increased in between?
Something else, IRSN is reporting that they found also contaminated water in several "wells" outside of buildings of reactors N°2 and 3.
I see that has been reported (in other recent sources) contaminated water in a trench outside of these reactors, maybe is it the same info or a related info.
Mar28-11, 08:43 AM   #1706
Quote by Gilles View Post
a possible scenario (sorry I'm not an expert in nuclear reactors, I just try to imagine reasonable conditions ) : control bars have been damaged at least at the top of fuel assemblies, due to very high temperatures and/or chemical reaction with steam, and have been partially destroyed. The top of fuel rods can become critical when they're bathed with liquid water, the boron concentration being too low to absorb neutrons. Some kind of self-regulation occurs, when liquid water is above the top of damaged bars, nuclear fission can start periodically - it then produces much more heat that vaporizes the water and the water level decreases, until the system becomes sub-critical, and steam recondensates. The period and amplitudes of oscillations are such that the whole thermal and pressure inertia is enough to smooth the variations, acting like a low-pass filter. Is it conceivable ?
The answer to that (as you described it) is no.
Mar28-11, 08:47 AM   #1707
US 7th flotte is sending fresh water to FUkushima (2'000 m3) :
the question is, how long do you thing, this fresh water will last given the need of water to cool down the reactors and the pools ?
YOKOSUKA, Japan - Commander, Fleet Activities Yokosuka (CFAY) began transferring fresh water to two fuel barges, which will be used to support cooling efforts at the Fukushima Daiichi nuclear power plant March 25.
YOKOSUKA, Japan (March 25, 2011) – Barge YOGN-115, carrying 1.04 million litres (275,000 gallons) of fresh water, departs Commander, Fleet Activities Yokosuka (CFAY) to support cooling efforts at the Fukushima Daiichi nuclear power plant. CFAY port operations cleaned and filled two barges, totaling nearly 1.89 million litres (500,000 gallons) of fresh water. (U.S. Navy photo by Mass Communication Specialist 3rd Class Mikey Mulcare)
A total of 1.89 million litres (500,000 gallons) are being distributed between the barges that have been cleaned of fuel to support fresh water. The first Barge YOGN-115 departed CFAY at approximately 11:00 a.m. and will be escorted by a Japan Maritime Self Defense Force multipurpose support ship JS Hiuchi (AMS 4302). The second barge is scheduled to leave within the next 24 to 48 hours. The water will eventually be used to replace the seawater currently being used in cooling efforts at the plant.
“We have two barges here,” said CFAY Operations Officer Lt. Cdr. Michael Weatherford. “They can both hold up to approximately 300,000 gallons of fresh water each. But the max capacity is reduced to make the barges seaworthy for ocean travel,” Weatherford explained. “The request was for one million gallons so when I told them we could get 500,000 gallons we started working on getting these barges released from our custody over to the [Japan Maritime
http://www.c7f.navy.mil/news/2011/03-march/069.htm
Mar28-11, 08:49 AM   #1708
Are the daily updates still coming out from TEPCO re. reactor temperatures, CAMS and containment pressures?
I haven't seen any new data for a while.
yes here is the latest http://www.meti.go.jp/press/20110328...10328008-3.pdf
Mar28-11, 08:56 AM   #1709
Admin
If the control rods are fully inserted and they are intact, then the water level in the core does not matter, and the core is subcritical. This is by design.
If the control rods were to melt and some of the boron lost, the core may still be subcritical, but by a lesser amount.
If the fuel material was washed out, then the core is less likely to become critical, because the fuel material would end up in the water, which is at the bottom of the core or in the plenum underneath the core, where there is a lot of hardware.
If somehow the control rods were fail and lose all their boron, and the fuel was intact, then criticality would be a concern.
One we know the situation/status of the control rods and fuel, then we can perform simulations on the margins to criticality.
An indication of control rod breach would be tritium and lithium in the water. I don't know if they are being measured.
Mar28-11, 08:57 AM   #1710
Quote by havemercy View Post
Considering residual heat loads for reactors and published heat loads for SFP then there is enough energy to boil about 400m3 of water per day
With all the leaks they need a lot more
Mar28-11, 09:03 AM   #1711
http://www3.nhk.or.jp/daily/english/28_h28.html
"pumping in 16 tons of water every hour in #2, might cut down to the 7 tons that are evaporated every hour".
1. What happens to the 9 tons that doesnt evaporate?
2. How much thermal energy does it take to evaporate 7 tons of cold water?
3. Where does all this steam go?
Mar28-11, 09:10 AM   #1712
Quote by AntonL View Post
Does the US army not have transportable desalination units? A quick google search turns up there are units for flatbeds that have capacities of 140'000 GPD which I assume to be gallons per day and should be able to cope with generating enough water.
Mar28-11, 09:13 AM   #1713
Quote by jlduh View Post
I assume all of you posters are aware that they (TEPCO) tried to and succeeded in adding copious quantities of seawater to the 4 reactors and spent fuel pools, after significant explosions damaged upper portions (and possibly seals on the primary containment-not RPV). They did this during a station blackout and probably had to rely on analog guages, if that, to determine flows and pressures. Also, the unit(s) radwaste systems collect water from floor drains throughout the plants, including the Turbine buildings. The radwaste systems have a finite limit on their capacity. To protect the radwaste tanks, there are overflows to other areas where the water can be collected or disposed of, but not in a controlled manner. Now with all the water being washed over the spent fuel pools and out of the RPV, there is a chance much radioactivity was also washed over and out of the reactor building. Also, there were deliberate discharges from the RPVs to keep them from going solid with water and bursting from hydraulic effects. When ever they stopped pumping water into the RPV or Primary Containment there was the inevitable back flow of fluids due to increased RPV pressure or via the vent path. During normal operations connecting piping systems and hoses can involve less than leak tight fittings, even under the most favorable of working conditions. The reactor radwaste systems are inter-connected with the Turbine Building since there is also contaminated water to be collected from the Turbine Building. Under the best of conditions such a large piping system is fraught with leaks and failed valves, including check valves. Now the magnitude of the assault on the Japanese plants, I would expect many piping systems designed for normal operation to not perform as designed. Water, water everywhere and not a drop fit to drink or step in!
Let me tell you, things happening at the plants are totally new to the workers and managers and the high radiation levels significantly hamper making insitu observations and corrective actions in timely manner. Insitu photos/videos and observations, radiochemistry and radiation measurements, stablizing reactor pressures and temperatures, and getting reactor plant system guages back on line; are the only way to accurately determine the damage and future recovery actions. Speculations based on views of the exterior of the Reactor Buildings is welcomed fodder for the uniformed masses.
Mar28-11, 09:14 AM   #1714
Admin
Quote by jensjakob View Post
About 18-19 GJ, depending on the initial temperature.
Unless I am wrong.
Mar28-11, 09:25 AM   #1715
Use this website:
http://www.nisa.meti.go.jp/english/
Mar28-11, 09:25 AM   #1716
Again, every day that passes amazes me to see how weak and improvised is the response on the ground to control the consequences of this catastroph. I understand that Japan is fighting the consequences of a terrible earthquake and tsunami in addition to this nuclear crisis, but it seems that the autorities are continuing to put the responsability on Tepco shoulders to control the situation, and try to keep up with what's going (and regularly when a mistake is done, they say: "i urge you to improve your safe safety management for workers",or "I urge you to be careful when you transmit wrong measurements". It's like a scenario where a private company deals with regulation autorities and these ones tell them: "this is your responsability to manage this mess, and please do it in accordance with regulation standards and requirements")
We will have maybe the first Iso 14000 certified nuclear catastroph in Fukushima (in words, not in facts of course!)?
ok i'm a little bit sarcastic, but...
This is no more a tepco problem, this is 1) a Japan problem and even more 2) an international problem! Is the Japan state so weak to take the lead around this mess? Of course Tepco knows more about the plant than Japan autorities but again this is a different subject. Where are military resources from Japan? Two weeks after the beginning of the crisis we talk about a barge with 2000 m3 of fresh water coming to rescue, and this is from US troops? That's almost a joke to me...
This is a situation of great exception, and a lot of people in the world are waiting for an international response to this crisis, I'm not even sure we can talk of a Japan response until now based on what we saw in the last 2 weeks. I don't know what is going on with international experts and resources on the ground, but if this is a (long and difficult) battle against this damn nuclear plan that is going on (like the BATTLE of tchernobyl has been called), then when will this battle get large adequate exception means to be won?
I've always been impressed with the vocabulary used in civil nuclear industry (for example, the protection enveloppes are called "lines of defense", Reno DEANO just above is talking about the "assault on the japanese plant" ;o)) and this is related with the fact that civil nuclear has been historically a direct "byproduct" or sister of military nuclear (to make bombs plutonium was required). For the russians in Tchernobyl, from day one it was clear: this is a state and military problem with state and military -huge- ressources and management to cope with the accident (of course no war is clean in reality even if some use a vocabulary like "chirurgical weapons" to create the impression it can be: the tchernobyl battle was also a "dirty" battle from environment and human standpoint of course).
I don't know if i express well the point that i saw several times expressed in one way or another on this forum but clearly, i see a huge difference in scale between the problem and the "solutions". Like if everybody was willing to underscale the response in order to underscale the problem... I really don't think that now that the "toothpaste went outside of the tube", a private company can handle the crisis (even if from the juridic standpoint they are probably responsible), the scale has to be upgraded to one or two levels concerning the strategical leadership.
I'm talking about Leadership. Time is critical and involves some leadership decisions to be made. The inertia from this standpoint is blatant.
EDIT: an other example of the weak and confusing leadership from the state standpoint (i already mentioned earlier on this thread this problem citing an interview of the Minamisoma's mayor who was upset with unclear decisions from government): More evacuees return to homes near nuclear plant!
http://www3.nhk.or.jp/daily/english/28_14.html
How hell can peole there understand something to the misleading communication of authorities and unclear leadership scale of the current problem? "No evacuation order between 20 and 30kms (just "advice" to leave on a volunteer basis) for the two first weeks must mean that it is not so serious, this is a plant problem and the autorities are not even steeping in to take the leadership on the site, this is a sign that the situation is not so serious": isn't this that a lot of japan folks not knowledgeable of the details can think and spread around?
Mar28-11, 09:31 AM   #1717
Unless they are trucking it off site, they will eventually run out of space to store the contaminated water. All of the concrete basement structures will eventually adsorb tremendous amounts of radiation that can only be eliminated by carting the cement away. (Not Practical, and it would add to air particulate radiation), so they need to cap those highly radioactive spots once they figure out what to do with the Reactor cores/Lava flow (depending upon what you believe is happening.)
They have got an environmental mess there that they will be tending to for a great, great many years.
New Reply
Tags
japan, nuclear
Thread Tools
Similar Threads for: Japan Earthquake: nuclear plants
Thread Forum Replies
8.9 earthquake in Japan: tsunami warnings Current Events 671
New Nuclear Plants Nuclear Engineering 9
Gen IV Nuclear Plants Nuclear Engineering 10
New Nuclear Plants Nuclear Engineering 14
Astronomer Predicts Major Earthquake for Japan General Discussion 65
